I purchased this item new about two years ago but it has never cooked anything as it only just warms up - even on high setting!
Is this a slow cooker? If so , it doesn't get hot, you cook casseroles in it for 8/10 hours, prep all your veg and meat, saute in a deep frying pan, add stock or a casserole mix, bring up to boil, tip into your cooker, switched to med/hot and leave, the ides is that you do prep night before and cook overnight, or first thing in morning and leave to cook all day
SOURCE: Lost manual for cook essential model # cepc600s.
You can get the manual for the Cook's Essentials CEPC600S Pressure Cooker here:
http://www.qvc.com/man/k/K97438_man.pdf
SOURCE: cooks coffee pot stopped working
I bought the coffee/espresso maker. The espresso side still works, but the coffee side does nothing. I only had used it for about a week, but that was long enough for me to throw the box. I was going to contact the company but I see that will do no good, so my suggestion is to buy a new one (same exact model) then put the broken one in the box and return it. You will have a new coffee pot, and you won't be out anymore money.
SOURCE: lost owners manual
Here's a link to this manual directly from QVC...
http://www.qvc.com/man/k/k37000_man.pdf
SOURCE: Instruction Manual Cook's Essentials Pressure Cooker
All Cook's Essential Pressure cooker manuals (made by Fagor America) can be found at www.fagoramerica.com including replacement parts as well!
SOURCE: I'm looking for the lid to a Cooks brand 7qt oval
Did you ever find a lid? I am looking for one also. Thanks for any help you can offer!
1. Place food in stoneware according to recipe.
2. Plug in Smart-Potâ„¢ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POTâ„¢ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Potâ„¢ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Potâ„¢ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Potâ„¢ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Potâ„¢. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Potâ„¢ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
This refers to a Breville AWT MM11 One Pot Cooker which should be posted in the Crock Pots Section!
