Question about Hanns.G Corporation HW173D Monitor
Driver software not installing - and screen res wrong
I've just bought a 28" HG281 Monitor.
I'm trying to use it with a laptop with Windows Vista, but it makes everything ridiculously wide. I've tried adjusting the resolution, but there isn't one that's wide enough - 1600x1200 is the closest.
I suspect I need the driver software, but when I try to install it, I get an error message. Nothing very specific - just that ins has stopped working and windows is looking for a solution.
Any suggestions?
  • 30 Answers
SOURCE: connection problems??
Check all power connections and surge arrestors to the ON position. Or if possible, try hooking up the monitor to a different source. You can use for instance, a laptop, some dvd players using s-video, etc. If the monitor works, then try a different video card. When buying components for assembly at home, it's not uncommon for them to arrive unoperational or DOA. Use a reputable dealer that has a good return policy. Hope this helps.
Posted on Feb 24, 2008
skotkolr
  • 558 Answers
SOURCE: Cannot go over 1600x1200 resolution
did you get info with the graphics card? not all can go high some are lower resolution for reasons.
and be aware that monitors can not go up in resolution forever they have a max limit so based on frequency you are using you may only get 1600 x 1200 1650 x 1080 is as high as this card will go it is listed on the side bar here under editors choice.
based on monitors freq settings you may need to adjust that to get to the max
http://www.sapphiretech.com/us/products/products_overview.php?gpid=261&grp=3
Posted on Mar 22, 2009
  • 6 Answers
SOURCE: Cannot access RHS of screen when on high res.
Search a better screensolutiom. Start with lower solutions
Posted on Aug 25, 2009
SOURCE: monitor wont support 1600x1200 resolution
I had a similar problem recently, green bar down middle which became "scratchy" and would come and go. I fixed (I hope) by unplugging the plug to the internal LCD panel assembly, cleaning with IPA, and re-plugging. All the covers and metal shields had to come off to do this though, a bit of a pain, and risky to the front of the panel.
Or it could be a timing issue, I know the L2035 only likes to be fed the right graphics "timings" over DVI and VGA. If out, you'll end up with an offset picture that can't be fixed by adjusting position in the monitor's menu. Re-set to standard graphics driver timings and it goes away.
Posted on Mar 19, 2010
  • 148 Answers
SOURCE: A new ASUS VE208T with
The resolution option can be found by right clicking on the desktop and click properties. Then go to the settings tab. That is where you will be able to adjust the resolution settings for your monitor.
Thanks for using FixYa!
Posted on Jul 08, 2011
NVIDIA + BenQ incorrect resolution
Hello try to renew the graphic driver from here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Please choose the graphic card model in selection box.
Remember also to choose your windows system.
My advice is to uninstall all the the old software, before you install the new.
Try to change the screen resolution, when the installation is done.
Good luck
Mar 10, 2013 | Computers & Internet
Video Driver won't work
Hi There
Firstly When You Install A Driver You Have To Edit Screen Res Your Self Some Times. Give It a Try First If It Dont work Id Be Happy To Offer Further Assistance.
Regards
Alex
Mar 06, 2013 | Computers & Internet
Can't Recover Vista CD ROM Device Driver
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Mar 09, 2012 | HP Presario Computers & Internet
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
My integrated wepcam on my Hp Pavillion 6915nr Laptop, is not being recognized. I can not find it in the device manager. I've update bios. and pretty much all of the updates. How do I locate in the...
You can try to install Webcam driver. You've not mentioned your OS; i think you use Windows 7. But HP only support Vista. You can give a try to download and install Vista driver. In most cases it solves the problem.
Here is the links for Vista 64 bit Webcam driver:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-47244-1&cc=us&dlc=en&lc=en&os=2093&product=1842155&sw_lang=
Alternatively, you can solve the driver problem by installing HP Software Update
Aug 11, 2011 | HP Pavilion dv6000z Notebook
Blue screen
BSOD? Okay, this is what you do, bash your head on your desk first because you've probably installed or bought Windows Vista. Then, go buy Windows 7 and install it.
Jun 20, 2011 | Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Resolution
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
I have LG 700S 17" Monitor
Try tapping f8 when you start your computer and when at the MS startup menu choose
  • Enable low resolution video (640x480)
  • and if windows starts update your video driver and that should fix the problem, when you restart more than once the options go back to default (not low res video,whatever video driver is installed)
    Mar 12, 2009 | LG Studioworks 700S 17" CRT Monitor
    Screen blinks on and off - Hardware or Software?
    uninstall the dispaly drivers and see if the problem persists, if it doesn't then vista has installed the wrong drivers, try download from the latest drivers for your machine
    Nov 14, 2008 | Gateway MT3705 Notebook
    Mitsubishi Diamond Pro 930SB limited by Vista
    Go to settings and uncheck "hide frequencies my monitor does not support." now go back and see if 120h isn't an option.
    Mar 30, 2017 | Mitsubishi Computers & Internet
    Hanns.G Corporation HW173D Monitor Logo
    83 people viewed this question
    Top Hanns.G Corporation Computers & Internet Experts
    nm8r
    Level 1 Expert
    Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
