Question about Kenwood VR-407 Receiver
No digital or dts output
I have digital audio sourses hooked up to all the digital inputs in the back. I've never had this problem before. I usually set the audio setting on "auto" and the receiver will change to "digital" or "dts" on the display in front. Any ideas? Thanks, jballgame
I have this exact same problem. I can only get it to play in ProLogic, Stereo or 3-stereo. But no DTS or 5.1. I have it hooked up to a blu-ray player via an optical audio cable.
Posted on Sep 12, 2009
I have the same problem, did you ever find a solution?
Posted on Jul 26, 2009
Mine is now doing that
Posted on Dec 27, 2007
How do I get audio from tv to receiver?
There should be audio output's on your TV and cable box. There are usually multiple options on most newer model a/v equipment. If u check the manual look for the page showing you about the various connections on the back, you're lookin for anything to do with audio output, there are many different types optical, digital, and analog. Again depending on your specific equipment there's almost always at least one way you can connect them
Feb 15, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
Can u hook it to a computer for sound
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
More-advanced sound cards would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
A digital-capable receiver would accept 44.1 kHz for normal CD or DTS sources. Some diddling with the output sampling frequency might allow digital multichannel audio to be decoded by the receiver.
Feb 11, 2011 | Harman Kardon AVR 430 7.1 Channels...
I am using a JVC RX6000 video audio receiver, and i hooked 5.1 BMB brand home surround speakers to it, and connected my ASUS media player that has optical output and used optical cable to connect to the...
This is a common problem. Each input will default to analog. Even though you have plugged an optical cable into the inputs of the Receiver, you have to change that input to digital.
For example, if you connect a CD player RCA cables to the Receiver. The receiver will recognize the Analog signal at the CD input. If you unplug the Analog RCA Cables and plug in the Digital optical, the receiver will still be at it's normal default input for the CD player which is Analog. You then have to switch the input, using either the remote or it may be able to be done with the buttons on the front.
As soon as it is changed to Digital, you will get nice sound.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | JVC RX-7000V Receiver
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
My receiver will not play in dts mode at all. (RX-V 2400)
Page 4 of the manual discusses the Input Mode button and how it prioritizes multiple audio signals from the same device. Could that be the case? Try Auto.
Page 35: "If the digital output data of the player has been processed in any way, you may not be able to perform DTS decoding..."
Page 83: The connected component is not set to output ... DTS digital signals."
Feb 03, 2010 | Audio Players & Recorders
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
Dts audio cd
kindly check digital settings on your dvdplayer. The output should be in digital domain. Are u using original dts audiocd or burn dts audiocd.
Oct 01, 2008 | Denon AVR-3806 Receiver
Hook up your Xbox to a Dolby Digital Decoder
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Kenwood VR-407 Receiver Logo
276 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
