Question about Sharp AL 1631 Copier
AL-1631 Copier puts a black line on each page
Read the manual and cleaned the Transfer Charger as instructed. That did nothing. The black line moves position with each page - sometimes on the left, the right, the bottom, in the middle.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
Does the line go across the page & move ? then your drum needs to be replaced.
Posted on Dec 02, 2008
I get a black line through my copy when using the multi feeder. I've cleaned the transfer cartridge 10+ times as directed without success. This line does not appear when using the platten only with the...
Clean the ADF Scanner glass. This is the small strip of glass that is separate from the platen glass. Right next to it. This glass is only used when the ADF (multi feeder) is used. All it takes is a small speck of something stuck to this glass to give you a line down the page as your documents are passed over the glass when copied. Anything stuck to the glass is therefor read as a solid line.
Clean this glass with some glass cleaner and a soft cloth and you should be fine.
Thank You for using Fixya.
Jul 01, 2010 | Sharp AL 1631 Copier
Line down the center of a copy. Tried cleaning
1.If your toner unite new.
problem on cherger or laser unite.
# clean its
If you are not,may does not supply developer.
Jan 19, 2010 | Sharp AL 1631 Copier
I channged toner in my sharp sf-2022 copier, now i have black smudge-like marks going across paper & the copys are real light begin to fade 1/2 way thru page? cleaned 1 of the rollers, helped a little...
Open front cover, you will see yellow knob, pull it down and pullout. Wipe the side with mesh with clean cloth and insert back. That's the main charge unit.
Pull the green lever to the left and pullout the transfer charger . Wipe the two wires carefully not to break them and insert back.
Do not try to remove the drum if you have no skills otherwise this should solve your problem.
Dec 10, 2009 | Sharp AL 1631 Copier
Lined Copies
If the line is only when you feed the original from the top feeder (not when you place the paper on the glass)....clean the narrow glass (called the **** glass) under the feeder on the right hand side
If that is not it new drum and/or blade is called for
Oct 28, 2009 | Sharp AL 1631 Copier
Sharp al-1631 lines on copy only when original goes through docum
Clean the narrow document scanner glass to the right of the main copy glass.
Mar 11, 2009 | Sharp AL 1631 Copier
Sharp Copier AL-1631. Copies with a black line (which moves positions on the page each time). Checked the manual and cleaned the part that it told me to. That did nothing to fix the problem.
If it only happens when using the document feeder (if fitted), then the small glass on the right hand side needs a clean ( normally tippex), if it occurs when copying from the glass and doc feed then your charge corna needs cleaning
Dec 01, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
205 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
