Question about RCA F32650 32" TV
Bad electrolytics vert circuit
Hi:
You recently posted a response to my RCA issue. Thank you for that. Any idea what this problem that you have identified (bad electrolytics vert circuit) runs to fix? The TV is quite large to lug around and if this is an expensive fix, I'd rather just recycle it rather than dragging it to the repair shop and back. Thanks in advance!
  • BigBadNumber Dec 04, 2008
    Thanks. I appreciate all the feedback! I will likely go ahead and get it fixed.
  • 121 Answers
If pict good etc prob worth repair guess 100.00
Posted on Dec 03, 2008
Retarce line
Diagonal retrace lines at the top are usually the result of bad electrolytic capacitors in the vertical deflection circuit most vert. deflection circuits derive operating B+ from a horizontal flyback transformer winding rectified & filtered usually around 24 volts the electrolytic capacitor on this supply loses capacity or may totally go open causing the retrace lines,sometimes other electro. caps in the vert circuit can cause this too, depending on the age of the tv you may find multiple substandard electrolytic caps it's best to test all for capacity & esr. Without knowing more details about your tv brand,model and/or chassis i can't help further.
Apr 14, 2014 | Sansui Televison & Video
The tv i have is a RCA D61W20 and it will not come on . the power light goes on and off three times and nothing
Problem with main deflection board,bad electrolytic capacitors/Hi voltage circuit has bad connections,common to those RCA tv's.
Mar 22, 2010 | RCA D61W20 61" Rear Projection Television
There's a very narrow line (white) appears at the very top of the screen when the picture scene is mostly black. A verticle adjustment should fix it but where is it?? RCA F36TF720
it may be an electrolytic cap problem as most newer sets are controlled by an I.C. chip for horiz and vert timing/size/linerity
Nov 02, 2009 | RCA F36TF720 36" TV
No vertical deflection -Horizontal line on tv
check or re solder the ic of vert. defl.
Jun 09, 2009 | Sansui 27" TV
C640 power issue
To my surprise, dell provides dis-assembly instructions online: http://support.dell.com/support/edocs/systems/latc640/sm_en/sysboard.htm#1000473
I have the same problem but didnt see a bad solder (resoldered all connectors with no success). I may have a bad AC power supply or bad charge circuit - no idea)
Jan 05, 2009 | Dell Latitude C640 Notebook
RCA TV Model F36650
bad electrolytics vert circuit.
Nov 20, 2008 | RCA F36650 36" TV
Mistubishi tv vertical hold not working
you can go to this link and one of thier tecs can help you out just leave them an e-mail with your model number and they kow how to do the bypass
Apr 10, 2008 | RCA D52W19 52" Rear Projection Television
Picture in narrow line on 35" Tube set
The problem you are describing is called loss of verticle deflection. You will find this will require diagnosis and there is no simple answer to this repair. Most likely there will be either bad electrolytic caps or bad vert. output IC in the vert. circuit.
Mar 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wide white horizontal bar
do actual replacement of all electrolytic capacitor surrounding from the vertical ic.
Jan 19, 2008 | Sanyo DS24425 24" TV
Buzzing noise with no picture or sound.
The power supply is telling you that it has a short. I think you have a bad high voltage transformer in the horizontal deflection circuit. I've repaired several RCA's with this very same problem. The newer RCA's are vert prone to high voltage transformer failure ! Stargazer
Aug 20, 2007 | RCA F36649 36" TV
RCA F32650 32" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
