Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Pt53tw53 panosonic does not power on 5 blinks then off
NUMBER OF FLASHES
POSSIBLE CIRCUIT
LOW D.C.
CONVERGENCE
HHS
5
IC4511
6
IC4518
IC4511 is on DG board. Asterisk indicates whole board is to be replaced. In schematic, labeling on IC4511 indicates it does some form of video processing. Manual instructs to add an "S" at end of board part number when ordering.
* DG-BOARD
TNP2AA126
PIP PROCESSING, SPLIT, SEARCH, FORMATS
Posted on Dec 04, 2008
Panosonic l th32 22cd long blinker is it rectify without changing main board?
Check your various power supply voltages and see if they are correct
Oct 31, 2017 | Televison & Video
Why does my panosonic projection tv have a black screen?
This signal indicates that the fault is with the 5v SOS D Board.
Apr 22, 2017 | Televison & Video
Panosonic lcd tv . when switch it on green lights blinks for some seconds and it tens on and for some minutes it tens to red and blinks but no sreen
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jul 24, 2014 | Televison & Video
Panosonic tc-p42s1 10 blinkes
This should help diagnose the problem.
Apr 04, 2013 | Panasonic TC P42S1 42 in. Plasma HDTV
Panosonic will not turn on
a lot of course will depend on the model number of this set, look closely to see first if the power light is blinking a specific number of blinks with a pause---this is called a error code.
Nov 01, 2012 | Televison & Video
My Panosonic TV Model# PT-47WX42F will not turn on. It clicks like it wants to turn on but does not. The power light is flashing 5 times
5 blinks is error code for short on 140 volt line inside the set; it usually means the Horz output transistor is shorted. If you have a ohm meter (used for checking fuses etc) there is a simple test to see if this is the problem.
Also associated with this is a bad capacitor near it (Location for the Transistor is C509 and the transistor should be location Q551)
Location numbers are printed on top of board near part; both parts are on (as seen from back) far right board near the large black part with big red wire coming out of the top.
Transistor is just to the left of it and cap forward about 3 inches.
If this information told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 30, 2010 | Panasonic PT-47WX53 47" Rear Projection...
HOW TO LEAVE A VOICE MESSAGE ON A PANOSONIC kX-t7636
Your VM has an extension, usually 165 or 500. You forward your phone to Voice Mail by dialing *710x 500 # where x is 2 for all calls, 3 for busy, 4 for no answer or 5 for NA/Busy. I use 4.
The FWD/DND light will blink and the display will say Call FWD (condition) 500.
Now, all calls, both from the inside and outside will forward to the voice mail system.
Carl
Apr 15, 2010 | Panasonic KX-T7636BK Digital Telephone...
Panasonic PT53tw53-TV shuts down, red blinking light,
Replace diodes 6301,6116,6117. on G board.Diodes will sometimes read good but break down when under load.
Jan 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Panosonic Hdtv 47 in projection 1080i
Replace IC's with PANASONIC part # C5AA00000203 only...
DO NOT use generic cheap junk .......only makes the repair worse......
Terry.
Jul 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
270 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
