Home | Sharp | AL 1631 Grayscale Copier | Sharp Copier AL-...
Sharp AL 1631 Grayscale Copier
Problem for Sharp AL 1631 Grayscale Copier
Sharp Copier AL-1631. Copies with
By sixuvusltd on Dec 01, 2008
Sharp Copier AL-1631. Copies with a black line (which moves positions on the page each time). Checked the manual and cleaned the part that it told me to. That did nothing to fix the problem.
Comments:
Dec 02, 2008
- The black line occurs at all times, with the feeder and when just placing the page on the glass.
Dec 02, 2008
- What's a dirty charge corona?
Solution #1
posted on Dec 02, 2008
Not Helpful)
t13ebb
Rank: Master
Rating: 86%, 41 votes
If it only happens when using the document feeder (if fitted), then the small glass on the right hand side needs a clean ( normally tippex), if it occurs when copying from the glass and doc feed then your charge corna needs cleaning
Comments:
Dec 02, 2008
- Could be a worn drum or dirty charge corona
Dec 03, 2008
- Open the side toner, open the front door, remove toner. To the right of toner is the drum unit, remove. Have a look at the condition of the drum, should be shiney and clean, if it looks dull and scratched, replace complete unit. if it looks ok then on top of the unit there is a aluminium unit held in by two chrome screws remove and then remove the corona unit (can be a bit tricky). Once out, the under side has a grid ( a fine mesh), clean that and the under side as well, with a clean cloth and meths or similar. replace all items and test
Cheers
Was this helpful?
Yes
No
Popular Solutions for Sharp AL 1631 Grayscale Copier
Questions and Unsolved Problems for Sharp AL 1631 Grayscale Copier
Do you recommend Sharp AL 1631 Grayscale Copier?
Answer
Answer
I installed a fuser unit in my Sharp AL-1631 and change fuser warning did not go away. Is there a... (More)
Answer
My scanner lock is flashing but it's unlocked??
Answer
what's the most efficient way to communicate my sharp xe-a21s with my QuickBooks data file
Answer
The register says ppppppppp and the register is locked. What do we do?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL 1631 Grayscale Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 1507
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
