Question about Canon MultiPASS MP730 All-In-One InkJet Printer
My printer is not printing and sometimes blank paper comes out
  • 495 Answers
First check if job is there in the print queue when you print any document. Better reinstall the printer driver software again.
Posted on Dec 02, 2008
  • Manoj Rout
    Manoj Rout Dec 02, 2008
    Look for printer cartridge ink also if its dried up.
  • Manoj Rout
    Don't forget to rate me..if your problem is solved..
  • 3,037 Answers
Have you replaced the ink cartridge and tried a different one? Does this not work in the copy mode and the print mode or just the print mode? Let me know and I will tell you what you can do.
  • 734 Answers
Try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
  • Canon Master
  • 19,396 Answers
Try first reinstalling printer software from disk, if this does not work therre may be a faulty printhead or another fault.
  • Ginko
    Ginko Dec 02, 2008
    Try first replacing the cartridges,
    Try also the following power cycle:
    Remove cartridges,
    unplug the printer power cord and USB cable,
    wait 10 minutes,
    restart computer and assemble everything back,
    If the printer still does not start, test an USB replacement cable, and try a replacement cartridge.
    If still no luck, then the printer is faulty, probably a defective printhead.
    In this case you will need to take the printer to a repair shop.
    Sergeant:
  • 217 Answers
That meaNS EITHER THE CARTRIDGE IS COMPLETELY EMPTY OR THE INK IN THE CARTRIDGE IS DRIED UP.
CoachTim
  • 202 Answers
SOURCE: Printer will not print
Lacy, Other than obvious, Do you have ink?...Have you tried running the nozzle cleaner from with print properties? Has your ink maybe dried up. Try to reset the ink cartridge(s)..look at the bottom of the cartridge and see if the ink looks fresh(wet) or is it dry? Have you tried printing from more than one program? You can find other info here and download new drivers if need be. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQs&oid=41662&prodoid=46048264&category=Products Good Luck, Tim
Posted on Feb 04, 2007
SOURCE: paper goes through the printer
Just make sure the cartridges are not running out of ink. Try with different carts, It should work fine.
Posted on Apr 20, 2008
SOURCE: i got printer hp desk jet 1280 i could not print A3 size paper
Delete the printer and install it again using HP deskjet 1220C drivers. This actually worked for me when i faced the same scenario.
Posted on Jun 19, 2009
SOURCE: tvs msp250 champion printer problem?
PRINTER IS PRINTING DOTS AND INVERTED CROSS LINES INSTEAD OF PROPER ALPHABETS
Posted on Jul 08, 2009
SOURCE: printing is blank...no ink coming out on to paper
Your printer cartiage will be out of ink.
Or it will be dry cause of not used from long time.
Change the printer cartiage may fix this problem.
Thanks.
Posted on Oct 09, 2009
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Problem after refil
check here
http://www.youtube.com/watch?v=sOriLrbuBao
Apr 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
I get blank pages when printing. Sometimes all pages are blank, sometimes first and last page print, with blank middle pages.
hi,check your printing setting and then print.
or....
uninstall the printer then install the printer again then printer has default setting and print the paper.
sometimes printer current pages print wich is selected by setting.you must select all the pages.
to change the setting,,,
1-open control panel then open printers and faxes then check seeting.
Apr 12, 2009 | HP DeskJet 842c InkJet Printer
Printer says printing but no print out.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps on feeding papers, displaying printing message but with no actual print out i.e. blank paper comes out. please help. thanks!!
Darren.
darren.lee54@yahoo.co.uk
Oct 06, 2008 | Epson Stylus CX5200 All-In-One InkJet...
Paper goes through the printer as though printing but paper comes out blank
Apr 20, 2008 | Office Equipment & Supplies
My printer is not printing anything
check the properties of the printer , or any errors showing in the printer
if its not come check the cartridges in the properties panel sometimes it show ok but it will not print problem with the head
Mar 16, 2008 | HP LaserJet 2200D Printer
Blank papers comes when the print given
D ear team, Blank papers comes when the print given. Meanwhile it shown the error msg is: LSU Hsync error cycle power pls give me the solution NHPC Ltd.
Feb 03, 2008 | Samsung ML-3051ND Laser Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
64 people viewed this question
old marine
old marine
