Question about Frigidaire Kitchen Ranges
Oven will not open after maxx self cleaning cycle
Frigidare electric smooth top slide-in oven, turned on maxx clean cycle, it ran for about 2 hours then gave me an ''F'' code and shut down. the clear/off button seems to have no effect. the clear/off button will cancel time set but seems to not have any other effect. the red ''locked'' indicator is lit. it has been this way since yesterday noon. it seems to have done a fair job of cleaning but of course I don't think it went thru the whole 4 hour cycle. I plan on turning off the power to the unit and waiting for a minute or two
  • jleevine Dec 02, 2008
    please note, I turned power to oven off and waited one minute turned it back on and got an F30 ERR message, the door did not unlock.
    Sergeant:
  • 217 Answers
This error code can be of two reasons.
F----30--MEANS(Open probe connection.)
F----31--MEANS(Shorted Probe connection)
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
if the error codes other then this occur then try this
1. (F10 only) Check *RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
2. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
3. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Posted on Dec 02, 2008
  • Frigidaire Master
  • 19,396 Answers
Unplug the power cord for thirty minutes, this should reset the oven.
  • Ginko
    Ginko Dec 02, 2008
    Try first unplugging the power cord for a while.
    If this still does not work do the following:
    Press clean and then cancel. This will reset the appliance.
  • Ginko
    Ginko Dec 02, 2008
    Try first the two reset suggested, unplugging the power cord for a while, and if this does not work, pressing clean and then cancel.
    If the error does not clear , then during the self cleaning cycle, the high temperature has damaged the temperature sensor probe, and it must be replaced. See f10 error code.
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
About 1 hour into the 4 hour clean cycle an alarm started gong off. Code is F3. Frigidaire smooth top electric slide in stove.
The F3 code means
The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. Check oven temperature sensor, 1100 ohms Good Luck
Nov 27, 2010 | Microwave Ovens
My oven is locked and i can not get it to open. i used the self cleaning maxx clean, and it beeped about 20 minutes before the 4 hours were up.
Here is a tip that I wrote about the self cleaning feature and the pit falls of it...
Also contains some ideas on how to get the thing unlocked...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 30, 2010 | Electrolux EW30ES65GS 30" Slide-in...
Oven door is locked and will not clear. I have tried to reset. Turned the breaker off, The only button that works is the timer. I am not cleaning the oven it was locked by accidentially leaning against the...
Hello JJ, Try pressing the "Clear/OFF" button to stop the self cleaning cycle. It will take up to an hour before the oven will unlock the door, if the oven has started to heat up for the cleaning process
You may have started the default 3 hour self-clean cycle, so you can attempt to reduce the time to 2 hours, by pushing the timer down so it displays "2" which would indicate the shorter cleaning cycle. Then at the end of the timed cleaning cycle, it should open up, once the temperature has cooled sufficiently for it to be safe to open, again, which takes up to an hour to sufficiently cool.
Typically, when an oven is accidently put into self clean mode, the timer "kicks in" and the timer has to run out before the oven will unlock. With the older mechanical knob timers, you could just rotater the timer until you reached the end of the pre-set time. With the electronic timers, you have to let the timer "count down" until it reaches zero before the oven will unlock the oven door.
Here's a link to the Frigidare site where you can select your specific FEF352 version and download a owners manual, free of charge.
http://www.frigidaire.com/manuals
Just enter in FEF352 and then scroll down the page until you find your particular version of teh FEF352 oven/range and then click on "complete owners guide" (english) to get the manual in an Adobe pdf format.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Frigidaire FEF352 Electric Kitchen Range
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
How do use self clean service?
CAUTION: SHOULD AN OVEN FIRE OCCUR,
CLOSE THE OVEN DOOR AND TURN OFF THE
OVEN. IF THE FIRE CONTINUES, USE A FIRE
EXTINGUISHER. DO NOT PUT WATER OR FLOUR
ON THE FIRE. FLOUR MAY BE EXPLOSIVE.
To set the controls for a self-clean cycle:
For satisfactory results use a 2 hour self-clean cycle for
light soils and a 3 hour cycle for average to heavy
soils.
1. Be sure the clock shows the correct time of day.
2. Press Clean. "— — —" appears in the display.
3. Press the Up Arrow until "3:00" appears in the
display for a 3 hour cycle, or press the Down Arrow
until "2:00" appears in the display for a 2 hour cycle.
4. As soon as the Up Arrow or Down Arrow is
released, "CLN" appears in the display.
5. As soon as the controls are set, the motor driven
lock will begin to close automatically and the "LOCK"
indicator light will flash. DO NOT open the door while
the light is flashing (it takes about 15 seconds for the
oven door to lock).
6. The "LOCK" light will glow until the cleaning cycle is
completed or cancelled, and the oven
temperature has cooled.
When the self-clean cycle is completed:
1. The time of day or “END” will appear in the display
window and the “Clean” and "LOCK" light will continue
to glow.
2. Once the oven has cooled down for about 1 HOUR
and the "LOCK" light has gone out, the oven door can
be opened.
3. If “END” is in the display and the “Clean” indicator
remains on, press Clear/Off. The time of day will
appear in the display.
NOTE: When the oven is cool, wipe away any residue
or powdered ash with a damp cloth or paper towel.
Stopping or interrupting a self-cleaning cycle:
If it becomes necessary to stop or interrupt a selfcleaning
cycle.
1. Press Clear/Off.
be opened.
3. Restart the self-clean cycle once all conditions have
been corrected.
How the ES 200 operates:
CAUTION: NEVER ATTEMPT TO REMOVE EITHER
THE BAKE OR BROIL ELEMENT WITHOUT DISCONNECTING
ELECTRICAL POWER FROM THE
RANGE. ELECTRICAL POWER IS CONNECTED
TO THE ELEMENTS WHENEVER ELECTRICAL
POWER IS CONNECTED TO THE RANGE.
The ES 200 electronic oven control system is made up
of three parts that control the bake and broil elements,
and the locking of the door in the self-clean cycle.
1. Electronic oven control.
2. Oven temperature sensor.
3. Oven door lock mechanism.
Dec 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Oven door won't open after self cleaning
it hapen to me i activated the self cleaning gently hit the top of door and turn the self cleaner off the latch came off was able to use the oven did not used cleaner again clean it manuelly did not whant to spend the money
Jan 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
