Question about Wharfedale Audio Players & Recorders
Connecting Wharfedale 9.0 speakers
Receiver - Yamaha RX - 570 (10 years old)
Speakers - Cambridge Soundworks - 2 small satellites and 1 sub
Wiring - The Satellites and sub are cross-wired and run on Channel A
Questions - 1. Should I just disconnect the two CSW satellites and connect the 9.0's to the sub? The cables are adequate, but could be replaced. New wires will have to be stripped.
2. Should I keep the CSW set-up the same and just hook the 9.0's up to Channel,B? If so, how would you recommend wiring them and what type of cable should I use?
    Sergeant:
  • 217 Answers
U can get the cables at radioshack websites for this.just order online.they will provide you.
Posted on Dec 01, 2008
Please tell me all the connections on movie star 60+
Each of the five satellite speakers connect directly to an AV Receiver that you buy a separate device.
Here's the back of the sub. The sub either connects to the LFE Sub Out from the receiver to the white RCA/Phono Left Input. Or you can use speaker connection cables, AV Receiver front L & R to Speaker Level Inputs, and then Speaker Level Outputs to the front satellite speakers.
Aug 16, 2014 | Wharfedale Audio Players & Recorders
My Yamaha RX-A830 won't play the sub. I've reset the speakers with the mic multiple times but it's still not working. I confirmed that the sub works on another receiver.
There is a difference between SUB and LFE. In 5.1 mode, the LFE is the ".1" channel. It will output bass only when audio information signal is addressed to this channel. In stereo mode, depending of the receiver setting, it can output normal bass when front speakers cannot handle low frequency. In setup menu, you'll probably have to set your Front speakers as "Small" to make the sub channel taking the relay in low frequencies. There also can be many other reasons for your problem but this might be the solution. Good luck!
Dec 02, 2013 | Yamaha RX-A830 A/V Receiver -
I have used the sound test to check my CS 5.1 system. When I test the subwoofers, there is no sound. I have played CDs with deep bass, no sound is emitted from the subwoofers. I have T-500...
One step at a time. Get the subwoofer to work, THEN play music through it.
You don't describe the electronics, IF you have a sub defined, whatever other steps it probably needs to pass LFE to the sub.
Register and download the manual for free at retrevo.com
Page 7
http://www.retrevo.com/support/Cambridge-Soundworks-T500-Speakers-manual/id/522bh631/t/2/
Apr 29, 2011 | Cambridge Soundworks Newton Series T500...
Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
Jul 26, 2010 | Yamaha Audio Players & Recorders
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Subwoofer does not kick in during stereo mode with front speakers
There should be an adjustment in setup that for 2 channel sources, you may have to enable the subwoofer output. Or alternatively, if the subwoofer output for 2 channel sources is in fact enabled, then increase the crossover frequency for the sub.
May 07, 2009 | Audio Players & Recorders
Receiver is shutting down.....
First, I have to compliment you on a thorough and comprehensive problem description and an apparent sense of how to troubleshoot. We're halfway there already.
Your Blu-Ray / PS 3 statement is intriguing but with the E-1 code that absolves it as the problem.
You have two opposing symptoms: the live failure says you have a short while the test mode implies an open circuit. We have to isolate everything and see if it moves to another channel.
Let's run with the "E-1: NO FRONT SP" error. I think it's trying to tell us we have an intermittent sensation of an open wire in one of the Front speaker channels. * Unfortunately, the manual doesn't break out Left and Right (but I'm sure the receiver knows) to help us isolate. You say it doesn't get past the Left test. I need you to decide by listening to the Left Front Speaker setup routine if it's really working or not, and if it seems to be working, maybe the receiver is really failing at the point it advances to the Right Speaker, assuming Right follows left in the sequence.
Verify for me: You swapped the two front speakers Left to Right and replaced both speaker wires with NEW wires and had no improvement.
I'm wary of a failcode that doesn't identify which of a pair is failing, so I 'd like to see ALL NEW speaker hardware and connections in place to avoid the pitfall of swapping the L & R with each other and having one of them be the problem without changing the symptom.
We can accomplish this easily: Try temporarily running the rear speakers as the Fronts just to see if the test can pass. If so, test the Fronts as if they're the Rears speakers. You should be able to just swing the receiver-ends of the cables among the speaker posts.
Something should change or else the problem is internal to the receiver. Good luck.
Apr 28, 2009 | Yamaha RX-V663 Receiver
No volume
do they plug in with a 3.5mm audio jack?
if so, i think you need to check your drivers for laptop output socket.
have you tried output with any headphones etc? do they work on laptop?
Feb 25, 2009 | Cambridge Soundworks SWBL SoundWorks PC...
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
43 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
