Question about Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW)
ZyXEL P-660HW-D3 password change
Help !
My younger brother was playing "admin" on my PC and changed password on my router, and now i have a big problem ! I can't establish a secure wireless network because i can't get access to router settings.
Please how to reset router to original settings.....?
  • andrija_kova Dec 02, 2008
    OK, i know that but i made it for only after 5 resets, now i have another problem when in bridge mode works fine, but when in routing it won't work properly... It connects to the net, pings right, but i can't get working connection on wireless or any other way....
  • 104 Answers
There should be a tiny recessed 'button' (usually more of a hole) in the back of your router. This may be marked 'reset'.
To use this to reset your router, the manual for the Zyxel P660HW router advises that your power LED should be on, but not blinking.
Push the end of an opened out paperclip into the 'reset' button (hole) for 10 seconds, or until the power LED blinks. This restores your defaults. The manual I have advises that your password will be reset to 1234. If you have a manual, please check this.
Good luck ;-)
Posted on Dec 01, 2008
Nat type is strict i cant play xbox
1 Make sure your ZyXEL Device hardware is properly connected (refer to the Quick StartGuide).
2 Prepare your computer/computer network to connect to the ZyXEL Device (refer to theQuick Start Guide).
3 Launch your web browser.
4 Type "192.168.1.1" as the URL.
5 A window displays
6 For administrator access enter the default admin password 1234 to configure the wizardsand the advanced features.(or if you already changed your password, enter that password)
7 On the right hand side of the screen you will see a drop down menu. click on NETWORK.
8 Then click on NAT.
9 Find the area to configure Port Forwarding.
10 The ports that Microsoft recommends to be open are:88 UDP, 3074 UDP, and 3074 TCP.
It also looks like you will have to set up a static address on your XBOX (I was looking at the .pdf for your particular router) You can do this by editing your network setting on your XBOX console, and then using this address as your "server" address when opening the above mentioned ports on your router.
ftp://ftp.zyxel.com/P-660HW-D1/user_guide/P-660HW-D1_3.40_Ed1.pdf
Nov 23, 2011 | Zyxel P660HW-D1 Router
Hi, I recently purchased an Internet Radio (TEAC WAP-R8900 for ~ $ 520 Euro/825 $ / 5100 Sek) that did not work against Zyxel model P-660HW-D1. I have tried for hours to get up and running Web radio to...
For the first steps, the WAP-R8900 start wizard shall assist you:
After first power on, the system will ask by a screen with flags for your preferred
operation language. Select the language by selecting the country flag with
UP/DOWN and LEFT/RIGHT buttons and then press OK.
READ MORE http://www.teac.eu/fileadmin/project_data/hifi/support/wap/WAP-R8900/manual/WAP-R8900-Manual-10-English.pdf
Oct 26, 2011 | Zyxel P660HW-D1 Router
Hor to reset the zyxel Prestige 660HW-D15
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Apr 05, 2011 | Zyxel Prestige 660HW Wireless Router...
I could access the router log in page and then go to the status page but I cannot go to the advanced setup page. I would like to know the setup page address that should be like...
For user access enter the default user password user to view the status only. The
following window will appear.
Administrator Access
1 For administrator access enter the default admin password 1234 to configure the wizards
2 Click Login to proceed to a screen asking you to change your password or click Cancel
to revert to the default password.
3 If you entered the admin password, it is highly recommended you change the default
admin password! Enter a new password between 1 and 30 characters, retype it to
confirm and click Apply. Alternatively click Ignore to proceed to the main menu if you
do not want to change the password now.
This router has a user password to see the status and an administrator password to change settings. Please mark this as solved if this solves your problem. If not feel free to ask more questions :).
Mar 02, 2011 | Zyxel P660HW-D1 Router
How can i config a dmz on a zyxel p-660hw-d3
Go to the router's IP, put your password then go to Network, NAT, Port Forwarding and put the DMZ IP on Default Server.
Nov 05, 2010 | Zyxel Computers & Internet
Recently, I bought ZyXEL Prestige 660HW-T1 router, it works fine, but sometimes GREEN Power (PWR/SYS) light changes to ORANGE color and lights for a few seconds and change backs to Green. Is it Ok? or...
You need to reset your router to defaults then configure it again then it will work fine.
For that press RESET button for 10 seconds it is in back side of router.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 02, 2010 | Zyxel Prestige 660HW Wireless Router...
How can i find my wep key for zyxel P-660HW-D3
See the attached manual and look up page 63 where is shows how to get to the wep key information.
the link is: ftp://ftp.zyxel.com/P-660HW-D1_v2/user_guide/P-660HW-D1%20v2_3.40_Ed1.pdf
If this solves your problem, leave feedback please.
Feb 06, 2010 | Computers & Internet
No connection via Ethernet between Zyxel P-660HW-D1 and PC
Hi Friend,
Before Connecting your internet we must check in ur system.
1.Go to Start---->Run------>type cmd----->in the black screen type ping 127.0.0.1
2.check wither its getting reply or request
3.If u are getting reply then ur system is perfect i.e., your NIC Card is installed properly.
4.check wither any proxy is enabled in the LAN settings.
go to browser--->tools---->internet options(Options)----->Connection--->Lan Setting--->there should noy be any tick mark in the boxes
Now we can check the connectivity,
1.Connect the PC from the Router Lan Port and the modem connectivity to the Wan Port of the Router.
2.Assign the Ip address as obtain ip address automatically
Right click networkplaces--->properties--->Lan Connection Properties---->double click the internet protocol(Tcp/IP).In the next box u must select the Obtain Ip address automatically
3.Now u switch on the modem after 30 sec switch on the Router.
4. Launch your web browser.
5 Type "192.168.1.1" as the URL.
6For administrator access enter the default admin password 1234 to configure the wizards
7 Click Login to proceed to a screen asking you to change your password or click Cancel
8 If you entered the admin password, it is highly recommended you change the default
9.Then u can configure the ip address
Regards,
Ayyasam
May 29, 2009 | Zyxel P660HW-D1 Router
Zyxel Prestige660HW-T1_cannot log-in to config page
have you tried admin/password or admin/admin
Mar 18, 2009 | Zyxel P660HW-D1 Router
Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW) Logo
2,787 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
