Question about GE WBSR3140DW Top Load Washer
Ge washing machine model wip4013srw how to fix the problem
Above machine wip4013srw washing machine heard also sometime like continue sound may be buzzer or any electric noise just on the machime and water supply either doesnot stop if stop doesnot comes and in fuzzy or slect cycle it stoped before spinning even i put off water supply mannualy by closing tap so where is fault in timmer or any where other place pl intimate me the machine is roufly 5-8 years old and electronic not manually rotating knobs also advise how the system works as at the bottam of machime one mechanical pulley is attached with string is possible fault fault there or in top electronic cck pl reply in detail and obliged thanks
    New Friend:
Ge 4013srw what does the water pump look like
Posted on Jul 06, 2013
How do you clean the washing machine. Mine smells and needs to be cleaned. I was told to pull out the agitator but that is impossible it seems.
Posted on Nov 14, 2007
  • 944 Answers
Unidentified buzzing noise in top loader machines is often due to a jammed or seized drain pump, especially if the pump has its own motor - sometimes just opening the front of the pump (usually under a panel at the base of the front, possibly behind a small - 3-4 inch - panel to one side or other) will clear it. behind the pump cover will be a sealed plug or similar, usually needs a half turn to undo. small pieces of wood or plastic sometimes are the cause, and may be "floating" on the drum side of the drain pump so may not be visible immediately. Make sure the machine is unplugged and check with your fingers to see if the pump blades rotate freely - they will have some resistance, but should not feel like you are pressing against something solid. If you still have the manual for the machine, somewhere you would expect to find detailed instructions for a user to clear the pump - it is not usually a difficult or complicated job however some machines have a very different drain system. You may have a certain amount of water comes out over the floor - this is normal. On an optimistic note, many of these machines are still functioning after more than five years with no problems, so it is likely to be minor. If you suspect the electronic control to be the reason for the problem, it may just be that it will not continue a cycle without properly draining, even if the drum appears to be draining adequately - check the drain pump. The pulley attached with string is slightly unusual - perhaps this is as a result of an old bodged repair and needs to be resecured - without more detail or a photo this is hard to say. Best solution for that would be if you could find a similar machine, possibly in a second-hand shop and ask to look at the base to see if there is anything obviously different with your machine.
Posted on Feb 17, 2007
SOURCE:
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Does water fill with lid open or does it fill only wit the lid closed?
no
and the lid has to be closed for the machine to start and continue operations
stick with GE
Jul 21, 2017 | Speed Queen AWN432 Washer
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
I have a GE Front load washer model # WHDVH660HWW. Everytime it goes into spin cycle the machine vibrates/shakes and it keeps stopping and then tries to reset. Eventually shutsdown. I ahve to open door...
Sounds like one of the internal suspension/dampening units for the drum unit has broken or become unattached. Am not certain what this machine has but removal of top and rear cover should allow you to inspect the items and arrange replacement as required.
Dec 20, 2010 | GE WSXH208A Front Load Washer
I have a GE Profile front load washer, model WPXH214AoCC..one day it was spinning and all of a sudden i heard this big pop..now, when it spends, it sounds like it will take off and fly. the noise is so...
You may have a broken tub support. This repair won't be cheap and I would not advise self repair as this is a complete tear down of the machine.
Feb 28, 2010 | GE Washing Machines
GE Washing Machine (model # GUSR2LOOT) drain problem
Check for a blockage in the water pump. If it does not drain first it does not spin. Check for power to the drain pump motor.If no pump blockage check the lid switch for continuity. No continuity, replace the lid switch.
Jul 03, 2009 | GE Washing Machines
Washing machine filled with water then quit working.
I pulled the back off and found where the noise was coming from. It was not the motor but I didn't know what the part was. I called an 800 number for G.E. sales and parts and spoke with someone about the dryer model number and he figured out what the washer model number was. I told him what I heard and where I heard it. He said only two parts make a humming sound: the motor and the water valve. I found a local parts dealer and bought a new water valve for $11.93 and now my washer is working again!
Mar 27, 2009 | GE Washing Machines
Loose tub on GE WJSR2080V
Reach (or look) over the tub, just under the metal top, at the four corners of the machine to see if the rubber tab dampening straps are OK. (not broken) If broken, use putty knife to push in 2 spring clips at very top of front panel (a couple inches in from the L and R side) and pull to take front panel off. Remove two 1/4 hex head screws holding top to side panels. Remove top. (looks like your model has a lid switch which can be unplugged by the back splash.)
Also check that the inner tub does not rock independently of the outer tub. If it does, pull agitator and tighten large left hand threaded nut.
Sep 13, 2008 | GE WJSR2080V
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
501 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
