Question about Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts
Electric Hydronic Baseboard Heater Under Electrical Recepticle
I am installing 3 Qmark Electric Hydronic Baseboard Heaters. Two are 2000 watts and one is 1500 watts. The existing outside walls where I want to install the heaters, currently have electrical outlets that will be over the heaters. I notice that the instructions say not to install the heaters under electrical outlets. Is this a National Electric Code requirement? Is this a real safety concern with Hydronic Heaters since they operate at a lower temperature? Why are they not allowing this? Is it because they are worried about electric cords coming in contact with the heating element? Is the element surface temperature any hotter than a typical forced hot water system surface temperature? What Should I do? Uninstall the plugs and put on blank covers? Be careful when using the plugs?
  • 706 Answers
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Regards,
Rick
Posted on Dec 02, 2008
Why doesn't heater heat up when turned on ?
  • I bought 3 convection heater ( model 052-2026 ) .Two of them stop to heat after 2 years using . The third, stop to heat last december. Canadian Tire ( store where I bougt the product ) told me to contact Garrison Company . Now , I want to get refund. Michel L?ger Quebec, Canada
Mar 04, 2014 | QMark Portable Hydronic Electric Baseboard...
This heater is a 2000 watt garrison convection wall mounted heater. the light is on but the heater does'nt heat up
The heater is disconnected or there is a damaged wire. You can try to open it up or bring it in. I would suggest bringing it in for repairs.
Elisa Jed ' http://www.encoremec.com/about
How do i wire a 240volt hydronic base board heater and thermastat
I need a control knob for my Marley electric wall heater model#fzl3004b
Dec 17, 2012 | Marley Electric Hydronic Baseboard Heater,...
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
Marley Hydronic baseboard heater not turning on
on the one that don't work use a clamp around ammeter and see if you are drawing current. no current, the heater element is shot!
Oct 23, 2009 | Marley Electric Hydronic Baseboard Heater,...
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
Installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Electric baseboard heaters
measure the room, then multiply the length by the width to get the square feet you want to heat. multiply this by 10 and that is the watts you need to heat the room assuming you are using standard 220/240v baseboards.
Dec 25, 2008 | Marley Electric Hydronic Baseboard Heater,...
BASEBOARD HEATER NOISE
HOW ABOUT THE MARTIN HEATERS I LIKE THEM BUT DONT USE THEM THAT HIGH
Dec 04, 2008 | Fahrenheat Electric Convector Baseboard...
Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts Logo
391 people viewed this question
Top Marley Heating & Cooling Experts
paulcarew
Ron Durham
janilly roswell
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
