Question about Victor 1530-5 Calculator
Set time and date on victor 1530-5 calculator
How do I set time and date on Victor 1530-5 calculator?
5 Suggested Answers
SOURCE: change time & date on the victor 1530-5 adding machine
I recently solved this issue with my calculator
Press and hold the time key when the date is dispalyed. When the display flashes enter the date as a six digit date (example 110608 for November 6, 2008) Time needs to be entered in military time when changing time.
Posted on Nov 06, 2008
SOURCE: Victor 1520A Calculator
buy my victor 1560 for 7 dollars
Posted on Jun 18, 2010
SOURCE: How do you set the
Immediately after entering the year part of the date, the display should revert back to a blinking first digit (in this case, the 0 to the left of the 8) while retianing all the following digits just entered. Simply press the Time/Date key again to lock in that date and stop the blinking. The same process applies for the time.
To clear the display of the time/date when using the calculator to actually compute something, press the C or CE button. This will result in a 0 appearing on the display. The unit is now ready for data entry.
Posted on Sep 23, 2010
SOURCE: How do I set the time on my calculator
To set the time on this calculator, you must press and hold the time key until the display is flashing 0. (Hint: you will want the date displaying when you are going to set the time as when you press the time key to hold it, it will switch over to the time.) Once the display is flashing you type in the time using the keypad. If you were going to set the time for 9:30, you plug in 930 and push the time key again. If you need to set it for a time in the PM you would have to use the 24 hour scale; for example 1:30 PM would be 1330. To set the date, you press and hold the time key with the date displaying until the display begins flashing. Again you would use the numbers on the keypad to enter the date and press the time key again to set it. For 1/20/2011 you would type in 12011.
Posted on Jan 20, 2011
Have a victor 1230-3 calculator / adding machine and my 2 year old grandson erased the tax and i cannot figure out how to get the 5% tax rate back in it.
1. Set the [GT OFF/GT ON/ TAX SET] switch to "TAX SET" position to select set mode for the tax rate.
2. Press "5"
Jun 17, 2011 | Victor 1230-2 Calculator
How do you set the date on a Victor 1560-6 Calculator. I held down the date button on the unit and the number is flashing. I entered 08232010 for Aug 23rd, 2010 and I am not sure of the sequence to lock...
Aug 24, 2010 | Victor 1560-6 Calculator
May 05, 2010 | Victor 1260-2 Calculator
I want to set the time and date on my calculator and need help Please give me the directions
1)Press TIME/DATE and then SET (The first digit of the month will flash)2)Enter the month MM using the number keys.
(The first digit of the date will flash)
3)Enter the date DD using the number keys.
(The first digit of the year will flash)
4)Enter the year YYYY using the number keys.
5)Press SET to confirm the date.
6)Press TIME/DATE and then SET. Enter the time using the number keys and press 12/24 to switch between 12-hour or 24-hour clock.
7)Press AM/PM to toggle morning or afternoon and press SET to confirm the time.
Oct 24, 2009 | Victor 1208-2 Calculator
How to use tax buttons on victor 1208-2 calcutator
1. Slide the "Rate Set/Item/PRT/On/Off" switch to "Rate Set" position
2. Enter the rate value.
3. Slide the "Rate Set/Item/PRT/On/Off" switch to "PRT" position.
You can also dowload the instruction manual
Jul 26, 2009 | Victor 1208-2 Calculator
Setting the time & date on model # 2640
Here is the manual: Click Here
You need this program to read it: Click Here
Mar 24, 2009 | Victor 2640 Calculator
Setting date and time
Turn the calculator on.
Hit the "C/CE" button and 0. will display.
Hit the "TIME" button so that the date displays.
Hit and hold "=" button until the month flashes. Now put in your date such as 11182008.
Hit the "TIME" button again so that the time displays.
Hit and hold "=" button until the time flashes. Now put in your time such as 1254. (12:54pm)
Hit "=" button to end.
Oct 14, 2008 | Victor 1212-2 Calculator
Change time & date on the victor 1530-5 adding machine
Aug 15, 2008 | Office Equipment & Supplies
Coleman and other companies have repalcment add rolls parts, Some are generic and some are original..
Apr 03, 2008 | Office Equipment & Supplies
Victor 1530-5 Calculator Logo
177 people viewed this question
Top Victor Office Equipment & Supplies Experts
David Burbee
David Burbee
Greg Cann
Greg Cann
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
