Question about NZXT GUARDIAN ATX Mid-Tower Case
Can't turn on Computer
Hi, I have bought this computer, and I tried to use it to build a computer using an Asus M2N32-SLI Deluxe motherboard, an AMD AM2 4600+ CPU (Dual Core) and a HIS X1950XTX. The problem is that the power won't turn on. After I turn on a 550W power supply that came with the case, the light on my motherboard lights up, but when I press the power button on the front of my case, nothing happens. Also, I'm fairly certain I have attached all the cables correctly.
  • 1 more comment
  • Pat Lee Jan 29, 2007
    I'm sure that i have connected the power cables. Is there any chance that the switch on the case could be broken?
  • Anonymous Nov 26, 2007
    no power to monitor even changed cards and no joy trust me all is connected but the thing wont work ????? i have 600w which is more than the 500w min for this board have a (bfg 7900 gs oc) gfx card tryed lowering the power demand by removing drives and cards nowt works need help wetherell@hottmail.com
  • Liger10777 Feb 12, 2009
    I have an old hp pavilion 512w and the cpu and its fan won't turn on and the led light in front won't light up either. My power supply works and the hard and both cd drives and the floppy work to I tried disconnecting everything and I pulled the ram from the computer and still nothing. I clean all the parts inside and try the one by one step. so can anyone tell me if the motherboard and cpu is bad or is it something else? I could really use the help
    President:
  • 2,961 Answers
Have you attached the CPU power cable from the PSU to the CPU power terminal next to the CPU. Double check you have the power and reset connectors tthe correct way around.
Posted on Jan 28, 2007
  • godisgreat22
    godisgreat22 Aug 06, 2012
    Thank you I took my battery off and plugged in the computer and it camw on!
I'm looking for a copy of a install disk for a ASUS M2N32-SLI Deluxe motherboard that I can download.
I assume that you are looking for the ASUS drivers, utilities, etc. You can go to http://www.asus.com and select service, support, motherboards, and enter your data to get to your model and select to download drivers. If you are looking for an operating system install disk you have to go buy that.
Sep 20, 2011 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
ASUS M2N32 SLI Deluxe - Fans Come On But Board Doesn't Post
there should be a four pin connector from the psu to the mobo,if thats not it try removing memory sticks one at a time, just make sure you leave one in
Apr 09, 2009 | ASUS AI Lifestylestyle M2N32-SLI...
Video Adapter Issue!
The on board video can be disabled in the cmos. Get in your setup and try to find it under "video". Also check your hcl for compatability.
Feb 28, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
THE AMD PHENOM 9600 QUAD
off course is compatible.
see this page
http://products.amd.com/en-us/RecommendedMBFilter.aspx
if you see for asus there is only 4 motherboards compatible and the last is the motherboards that you propose.
Sergio
Feb 29, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Second display not working
hi check for the BIOS settings for having both the cards work ..if not then try interchanging the card & slots with each other to check if one of it is faulty?
Bye Let me know
Dec 15, 2007 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Second LAN not working
To get this issue fixed. you can update the Bios. However, you have to take care when you do this..... [ Correct version and Correct date need to be checked]. Good Luck.
Sep 01, 2007 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
NZXT GUARDIAN ATX Mid-Tower Case Logo
242 people viewed this question
Top NZXT Computers & Internet Experts
David Payne
David Payne
Are you a NZXT Computer and Internet Expert? Answer questions, earn points and help others
