Question about Whirlpool Dryers
Dryer will NOT start
I checked breaker in fuse box. It appears to be ok.(light does come on when door is opened).
I checked outside and cannot feel anything blocking vent opening.
I disconnected door switch. (would this not eliminate it being the problem, as starter switch still does not work?)
If you think it can be the fuse, where is is located?
With a meter can I check starter switch by connecting blue wire with pink wire at the top of three wire triangle? (haven't found my meter to check switch). Thanks and God Bless!
jesuslovesyou.owen@gmail.com
  • jesuslovesyo Dec 01, 2008
    Hi again!
    Shouldn't I check out answers to my other questions such as the fuse and how to check the starter switch before disturbing the motor?
    Thanks and God Bless! Gary @ jesuslovesyou.owen@gmail.com
  • 89 Answers
1st reconnect the door switch for that is a safety element. 2nd check the terminals in the back of the machine and unplug it before you open the back pannel . Make sure they are clean and not corroded, then reattach and make sure they are secure. if this dose not solve the problem, you may have a bad or dead spot in the motor. Happy holidays biigg53566
Posted on Dec 01, 2008
  • Alan Matzke
    Alan Matzke Dec 02, 2008
    As to checking a fuse in the dryer the only the that would be in there is an overload breaker in the motor, that can not be checked. Did You say this is a 110 volt dryer?
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
70 Series Dryer will not start. Checked breaker box. Unplugged unit and checked connections and cleaned out built up lint dust. Door is sealed properly and light inside dryer is still on when door is
Check the motor for a blown fuse or circuit breaker attached to it, maybe a wire is disconnected from it. Another thing to look at is the actual switch on the top. Is it making good contact? Does it have a fuse or circuit breaker attached? Is it getting power?
Jan 11, 2013 | Dryers
Dryer won't start
Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok.
Next, remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it starts, or you can use a multimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. Another possible problem is that the door switch isn't functioning properly. You can visually check this by open the door and pressing the switch and listen for a click sound upon pressing and releasing .
In some rare cases the timer itself will prevent the dryer from starting. If you have tested both the thermal fuse and the door switch, and verified that the terminal block where the cord connects are ok then this will be the problem
Jun 08, 2012 | Kenmore Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Did a load last night but will not start today. checked 30 amp circuit breaker but not tripped. replace 30 amp circuit breaker anyway. checked outlet for AC and seems OK for 220 volt. dryer is showing no...
There are no fuses inside dryers except thermal fuses, and they don't run the light. Check the connections where the cord hooks to the dryer. Is this a digital control dryer or does it have a knob? Some of the digital ones use the control box to run the light too, otherwise it must be a wiring problem.
Dec 06, 2009 | Maytag Dryers
220 dryer intermittently tech says dryer ok electritien says wiring 2 dryer ok and breaker ok
This sounds as if the door switch is weak or the actuator is damaged and turning off the dryer before the cycle is complete. Make sure your dryer door closes and latches properly. If it quits mid cycle again press on the door and then press start...DO NOT open the door until you try this. If pressing on the door and pushing start gets a cycle start then I suspect you have a door switch problem. However,,,,, a dirty / cl;ogged vent or an air blockage some where in the vent / dryer air flow ducting can give you intermittent operation also. Make sure you check the outside flapper valve where the vent exits outside the house also. Hope this helps. Cheers!
Oct 15, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
kenmore elite won't start, Solve kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on... (More) kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
Jul 03, 2009 | Kenmore 63942 Dryer
Dryer does'nt run. checked breaker, thermal fuse, starter relay, timer stops when door is opened, starts when closed?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Apr 21, 2009 | Dryers
Amana dryer
Check your fuses or breaker. An electric dryer requires 240 volts to operate. In a fuse box system, 2-30 amp fuses are required for an electric dryer to operate. If 1 fuse is blown it will not start or heat depending on which fuse is blown.
In a breaker system the breaker can trip and sometimes look ok. Find your 30 amp dryer breaker and reset it by flipping the lever to off, then back on.
If this doesn't help, you may have a faulty door switch or maybe your door has loosened from the hinges and has sagged a bit, breaking contact with the door switch plunger.
If you can locate the door switch, push on the plunger... you should hear an audible click...if you do then the door switch is normally ok, but not always, it is just a simple test to rule a bad switch which is normally silent if it is faulty.
You may want to inspect for a burned wire or wire termination.
Make sure dryer is unplugged from the power source before inspecting!!!
Other than the previous instructions, it is difficult for a novice to diagnose the problem...call a technician in to fix your dryer.
1 more thing, Just because a breaker appears to be on, and/or you flipped it off then on, doesn't mean the breaker is ok. Fuses also can look good and be bad. A small volt-ohm meter($10.00) is a good investment for testing voltage, and to save time and money.
Hope this gets you up and running.
May 26, 2008 | Amana ALE643RB Electric Dryer
Open Questions:
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
