I have been experiencing sporatic error 99 messages for the past 1 week with my kit lens and my Canon EF-S, 18-55 mm, 1:3.5 - 5.6 II. This original Lens was bought along with the Camera. I have taken just over 10,000 exposures with my camera in 16 months.
If I change the lens, the camera works fine.
I have done this, but still the error continues :
1. Carefully clean the 8 gold color lens contact pins on the camera body lens mount with a pencil eraser. Do this while holding the camera so that any eraser dust will not fall into the camera.
2. Take out both batteries. Also remove the CF memory card.
3. With the batteries removed, turn the camera switch on for 3-5 minutes. He said that this clears the memory.
4. Turn the camera off and put the batteries and CF card back in.
5. Re-attach the lens and turn it back on. I get the Err 99 when I try to take a picture with my Canon Digital Rebel XT. It used to happen intermittantly, but lately I can't take a picture at all. I cleaned the lens contacts with an eraser, but it didn't help at all.
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: - 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert only a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: - 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: - 1. Turn off the camera. 2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon Digital Rebel XT / EOS
Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S...
i took off my lens to clean inside the camera and now the camera will not autofocus or work at...
(More)
i took off my lens to clean inside the camera and now the camera will not autofocus or work at all??? there was a black mark showing up on pictures...
My Rebel XT automatic sport mode photos are all blurry. I noticed that the shutter speed only reads...
(More)
My Rebel XT automatic sport mode photos are all blurry. I noticed that the shutter speed only reads around 13. There is also a pause indicating a slower shutter speed. Any suggestions?
Have Canon EOS Digital Rebel, get Incompatible JPEG format? erros on some pictures, not all. Tried...
(More)
Have Canon EOS Digital Rebel, get Incompatible JPEG format? erros on some pictures, not all. Tried several cards and seems to happen with all so don't think it is the card. Have no transferred pics to computer, only viewed on camera. please help......does camera need servicing or are we doing something wrong? Shooting high resolution.....
my canon digital rebel xt no longer powers on. it was working properly when stored in a case and...
(More)
my canon digital rebel xt no longer powers on. it was working properly when stored in a case and now it does not power on. I dont believe it was dropped or otherwise damaged. it may have been exposed to cold, but was in the house and at room temperature prior to being reused.
