Question about Logitech Harmony 880 LCD Remote Control
Rocker keys unresponsive
The "rocker keys" for the volume control and the channel changer require a lot of effort to get a response. The remote will be 3 years old on 12/09/08. Is there a way to clean these keys or does logitech repair units?
  • 3 more comments
  • ronniem890 Dec 08, 2008
    I have the same problem with a 890. How does one open the remote? After removing the 2 screws it is still tightly snapped together.
  • Moe Yacout Dec 30, 2008
    I have the same problem with my 880. When pressing DOWN it works fine but when pressing UP it feels like I have to bust the remote in half to get the channel or volume to change.
  • Anonymous Jan 17, 2009
    Exactly the same problem here. Volume Down is fine. Volume Up requires a *really* hard press of the button.
  • Anonymous Apr 10, 2009
    The "up" volume key and one the "prev" key is not functional. How to fixya ?
  • Anonymous Mar 14, 2014
    logitech slide changer HOW TO OPEN THE LOGITECH R400 SLIDE CHANGER
I had the same problem on my 676. I split the casing and cleaned the contacts and the bottom of the buttons with isopropyl alchohol about a month ago. Works fine now.
Posted on Dec 06, 2008
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
Dec 10, 2012 | Hitachi Clu-577tsi Remote Control
The TV does not respond to the channel changer. changed to a new changer and batteries but did not correct.
Do you mean changer is a remote control? Try to use manual buttons to see whether the TV work. If it does not response either the problem comes from the input/output controler or main board.
Aug 11, 2009 | LG 42LC2D 42 in. LCD HDTV
Oil leak from rocker box on 1996jeep cherokee2.5td
Get you a new gasket for the rocker cover, make sure you clean the mating surface good,and all traces of old gasket, and silicon etc. make sure you dont overtighten the bolts to the rocker cover. the torque for the rocker cover is 35 in lbs (4nm). as far as vavle clearance it is none adjustable. A clicking valve can indicate worn lifters, sometimes an oil change will quiet down noisy lifters. If noisy lifters persist you would have to service the heads. If you decide to do that yourself you can ask for a procedure on that too later on. Removal of the head is very difficult, because you need to remove a lot of things, and require you to do a timing on the engine.
Jul 01, 2009 | 1996 Jeep Cherokee Country
Fiero f2 motorcycle engine makes tappet sound when warm.sound disappears as temperature rises.engine is butter smooth with good milage. timing chain&adjuster have been replaced.Are the rocker arms a...
Rocker arms are responsible to move the valves and hence control the valve timing. So if youe mileage and power goes okay,i don think there is some problem with the rocker arms.
Mar 22, 2009 | 2005 TVS Fiero FX
Comcast Remote Can't Program My Sceptre HDTV
Thanks...this worked great for me. I used code 11100 on my Sceptre tv and it appears to be working perfectly!
Nov 27, 2008 | Zenith DBZN-311 Remote Control
Motorola cell phone sound problems W315
On the left side of the phone are two button: A rocker button and a push button. With the flip CLOSED, push the rocker button down. you will see Style:Silent. Push the other button until Style:Loud comes up. Push the rocker button down again to exit the function. Open the Flip and use the rocker button to set the Ringer volume. You can set the ringer volume however you want for each style. My phone swiches by itself constantly when I put it in my jeans pocket, very annoying.
Nov 01, 2008 | Motorola Mobility W315 Cellular Phone
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Logitech Harmony 880 LCD Remote Control Logo
279 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
