Vaillant turbo max plus 824e fault code s36. what is the problem?
5 Suggested Answers
  • 3 Answers
SOURCE: I have a Vaillant boiler
diaphram leaking or poor electrical contacts in microswitch
Posted on Jan 06, 2009
SOURCE: f22 on my vaillant boiler turbo max
Hi Guy's,
The answer is that your system is out of water pressure.
Usually there is a nob on the right under the base of the unit near to the small dial to the right of the front cover.
To enable the system to work correctly the needle on this dial should be in the Grey, about midway position.
Currently with fault F22 this will be lower to below the Grey and on the needle.
To bring the pressure back to the correct position, you need to turn this nob until you hear the water entering the system, KEEP AN EYE ON THE DIAL AND TURN THE WATER OFF AGAIN WITH THIS NOB ONCE THE DIAL IS IN THE CORRECT GREY POSITION AS MENTIONED ABOVE. DO NOT OVER FILL THE SYSTEM. I suggest you check this every six months or so.
Once this is corrected your unit will light up again.
Best of luck. Mike. N.
Posted on May 22, 2009
gasman44
  • 83 Answers
SOURCE: I have a Vaillant boiler Turbo Max VUW 242/1E,
You have a faulty diverter valve, this is a fiddly job, you need to call in a 'Gas Safe' engineer to diagnose and replace this
I hope this helps
Steve
Posted on Jul 10, 2009
TechieJon
  • 43 Answers
SOURCE: boiler not igniting
sorry, i think u have this in teh wrong category, it was filed under a laptop model called Valiant
Posted on Jul 23, 2009
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
Vaillant boiler ECO Max 824E F 20 error
Did you bleed the air from the pump ? Sounds like a air lock
Jul 14, 2017 | Water Heaters
I have a Vaillant ecoTech central heating boiler which has stopped working & is showing fault code F.76 Anyone know what this means please? Thanks
f76 over heat protection triggerd on heat ecxchanger , check water leval of just google vaillant fault codes
Jun 03, 2010 | Heating & Cooling
I have a Vaillant boiler Turbo Max VUW 242/1E, central heating is working but no hot water
I hope this helps
Steve
Jun 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Boiler problem
check the air flow,venturi in fan and pressure switch
May 16, 2009 | Sun Time NCAA Purdue Boilermakers...
F22 on my vaillant boiler turbo max
Hi Guy's,
Feb 01, 2009 | KDS Valiant 6380iPTD-01 Notebook
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
Boiler not igniting
Nov 23, 2008 | KDS Valiant 6380iPTD-01 Notebook
The code E 13 comes up on the panel and it cuts out
Maximum temp exceeded on ntc1(thermistor),,,either clean out heat exchanger,power flush of my first option replace thermistor...
Nov 11, 2008 | Water Heaters
Heating & Cooling Logo
218 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
