When I try to turn on my Sanyo PLCXF12NL Projector it cycles on for a second and then shuts down. Both the green power and red "lamp" light are on and there appears to be a "flash" of light before it powers off. It this a burnt out lamp or some other problem? What should I do?
  • gdennett Dec 01, 2008
    This is a projector not a projection TV.
  • 2,326 Answers
Click here to download the user's guide and go to page # 51 for more info on how the lights behave.
Posted on Dec 01, 2008
  • 1,879 Answers
Re-seat the lamp first
check ventilation (where the exhaust fan blows)
if issue is the same, a lamp replacement is needed (maybe burnt out or faulty)
  • 162 Answers
Yes there is something wrong with the lamp reseating the lamp might resolve or you may need to replace it.
    Sergeant:
  • 217 Answers
Just unplug the unit from main power outlet and wait for sometime and check out.if still the same problem the lamp should be replaced.or any capacitor is shorted out.needs replacement.
  • 19,396 Answers
I think this is a faulty lamp in need of replacement.
The lamp should be tested for continuity, and eventually replaced.
  • Ginko
    Ginko Dec 01, 2008
    The symptoms are the same as a broken lamp,
    try first the projector on a different ac outlet, just in case.
    To know if a lamp has blown, or is defective, you start inspecting the lamp visually, if it looks burned , than it needs probably to be replaced.
    To know if a lamp has blown you can use a multimeter and test the lamp for continuity.
    Post me back your feedback if you want, I will go offline soon, but I will answer you within 24.
    Thanks
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Lamp for PLV-Z2000: Hello , I have a Sanyo Z-2000 projector. Aft...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 12, 2010 | Sanyo Lamp for PLV-Z2000
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
SANYO PLV-70 - powers up for approx 5 secounds and then turns of
we had this problem and it ended up being that one of the fans under the lens assembly was not working, causing the system to shut down when it tested it at startup
Dec 11, 2008 | Sanyo PLV 70 Multimedia Projector
Sanyo XU50 not coming on after lamp replacement
Hi oatesy13
You will have to reset the lamp timer to resolve the problem.
Consult ypour user's manual on how to do this.
Should do the trick , If you do however need any further assistance , please send me a request and I'll respond to it.
May 13, 2008 | Sanyo PLC XU50 Multimedia Projector
PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Aug 11, 2007 | Sanyo PLV Z1 Multimedia Projector
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
