SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz) * In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode. * To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1) 1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode. TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS WHITE BALANCE ADJUSTMENT 1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ?? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3] Click on the Pictures to Zoom In BRIGHTNESS ADJUSTMENT 1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV) ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options 3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3] YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc. WHITE BALANCE ADJUSTMENT OF Component 1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit. WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ?? to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
Try going to settings and adjust the color settings, contrast etc. It is possible the set is damaged. If you bought it with a Visa or mastercard it automatically doubles the manufacturer warranty. they also have a great deal on extended warranty plans. Just call the number on the back and ask for Card benefit services or tell them you want an extended warranty.
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
one of three things here--if was normal before moved you may have a bad solder connection on the circuit board at the end of the picture tube--happens with age as connections can come loose.
The set MAY have adjustable controls on that board for drives and screens(red, green, and blue) that can be adjusted.
The set may only also have those in a hidden menu.
Considering age of set and cost for a replacement it might be better to replace it if none of above options are something you can try.
go to the manufacture website and look up your model of remote. Then program your remote to the tv. If you have done this then this next part is just for you. Usually u can adjust all the tv settings from the menu button. Be sure you are on the right input and AV setting if you can not access these settings then either go to manual operation or follow up with manufacture specs for your tv www.eliztech.com/remotes/ge-howto.php
