Question about Nu Mark Numark Cdx Table Top CD Player CD Player
CDX FROZEN UP!?!?!?
After doing the ribbon cable fix on one of my cdx's i have done the firmware update on the deck which seemed to freeze half way through so i had no option but to turn the unit off..... now like many others here when i turned it back on nothing happened yet all the lights are permanently on!! I have a big party organised for saturday and need the unit working for then, can someone please help me?????
  • 68 Answers
Because the unit freezed half way through a firmware update then it will have to be re-flashed and also these players do have some servo problems,if you havent had it fixed you can send it to us.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 06, 2008
Black out
this is a coincedence. The CDX-M800 had a HUGE problem with the ribbon cable on the face going bad, causing this exact problem.
$14.00 and some time will put it back into perfect condition.
http://cgi.ebay.com/ebaymotors/Fix-your-Sony-CDX-M800-flexible-ribbon-cable-CDX-M800_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ43947QQihZ020QQitemZ300287945333QQrdZ1QQsspagenameZWD1V#ht_2258wt_1213
Jan 21, 2009 | Sony CDX-M800 CD Player
My Numark Cdx won't read cds. It just ejects them.
GO ONTO YOUTUBE. TYPE IN NUMARK CDX FIX. Follow the video as instructed and this will be fixed.
Jan 04, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Aug 30, 2008 | Sony CDX-M610 CD Player
TWO CDX DECKS TWO DIFFERENT PROBLEMS
Fault 1: sounds like a servo or laser pick-up fault.
Fault 2: sounds like a broking track on the pcb or dry joint at the phono output stage.
If you havent had it repaired you can send it to us.
Regards.
Aug 13, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
May 30, 2008 | Sony CDX-M8800 CD Player
Will one of these disc changers hook up to the new decks?
According to the manual at sony's web site, the sony cdx gt520 deck does indeed use RCA style hook up cables.
May 15, 2008 | Sony CDX-646 10-Disc CD Changer
Sony CDX-M630 will work only with remote.
possibaly the issue is the ribbon cable that connects the faceplate to the head deck i had the same issue
Mar 11, 2008 | Sony CDX-M630 CD Player
Can you help me?
That ribbon wire is called as "data cable or IDE cable" You can find it at any computer store..Should cost you around 3$
Dec 01, 2007 | Sony CDX-M800 CD Player
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Dec 17, 2006 | Sony CDX-M8800 CD Player
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
307 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Greg Cann
Greg Cann
robert landry
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
