Question about Viking VGSC306-4B Gas Kitchen Range
Oven will not maintain temprature
My 30" viking professional is new out of the box. The range burners work fine, but the oven is unable to maintain temp. It reaches the desired temp, then cools down immediatly afterwards.
This is a parts problem, I think called the burner ignitor. It is a pn oven part. We have had it in the past and are experiencing it again. We have had our stove for about 15 years, so I guess it is not too bad a problem, but not inexpensive. The oven is letting the gas be off too long between reignitions, so it does not maintain temperature. The first time we realized the probelem was with the Thanksgiving turkey (pink in the joints.)
We had to have the part replaced about 7 years ago and the part was about a $200 part plus service call. I am sure it more costly now. Hopefully you can get yours under warranty.
Posted on Dec 14, 2008
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking VGIC3064BS top burner work but oven won't ignite
Have it fixed under warrenty. If your asking for help here you don't have the skills to DIY.
Dec 26, 2008 | Viking VGSC306-4B Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
341 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
