Question about Maytag MSD2756GES Side by Side Refrigerator
Maytag fridge s-by-s freezes alot of the stuff at the back and lower vege drawer
I have a Maytag side-by-side refrigerator. I have a thermostat in it to make sure I have it between the recommened 32-40 degrees. The thermostat is on the door and says 40. A lot of the stuff that gets placed at the back of the fridge, mostly the lower back tends to freeze. I have also had lunch meat freeze and that is in a separate drawer in the middle of the fridge. The fridge is 11 yrs old. Is this due to age or can this problem be fixed? Should I be checking the temp at a different location? Also, dispite not changing any settings, in the summer the temp will always tend to be too warm and I have to adjust the controls. Is this normal as well? Do I just get a new one? I assume they do not have these problems with newer models.
  • Anonymous Aug 11, 2008
    I HAVE A SIMILAR PROBLEM. I HAVE A THERMOMETER IN THE FRIDGE TO SEE WHAT THE TEMP IS AND I HAVE FOUND THAT THE TOP SHELF TEMP IS AROUND 40 - 42 DEGREES AND THE DRAW TEMP (LOWER SHELF) IS AROUND 30 DEGREES. I DO NOT UNDERSTAND WHY THERE IS SUCH A LARGE DIFFERENCE FROM THE TOP TO THE BOTTOM. THE AIR CIRCULATED FROM THE FREEZER INTO THE TOP OF THE FRIDGE (SIDE BY SIDE UNIT) DROPS DOWN TO THE BOTTOM AND I GUESS IT GETS SUCKED BACK INTO THE FREEZER. THERE IS ONLY ONE FAN AND ITS IN THE MIDDLE OF THE FREEZER BACK WALL ABOVE THE CONDENSOR(I THINK THATS WHAT THE COIL ASSY IS) BUT WE DO SEE COLD AIR BLOWING INTO THE MEAT DRAW - JUST NOT SURE HOW ITS GETTING THERE? BUT EVEN IF I SLIDE THE ADJUSTMENT KNOB FOR THE DRAW TO THE LEAST COLD AIR- THE ITEMS IN IT STILL FREEZE, LETTUS, MEAT, ETC.
    THE REASON I ASK ABOUT THIS PROBLE IS - IF I WANT MY TOP SHELF (WHERE THE COLD AIR COMES IN) TO BE AROUND 35 DEGREES - I WILL NEED TO TURN UP THE FRIDGE AND THAT MEANS THE BOTTOM WILL DROP TO 25 DEGREES AND START FREEZING EVERYTHING - WHERE'S THE MIDDLE GROUND? OR IS THERE SOMETHING BROKEN?
    HELP PLEASE?
  • 237 Answers
Actually this seems about right. The air flow in the fridge is usually from the back top of the fridge. That will be the cold spot then the air sinks down to the bottom and then recycles back into the freezer comp. to get cold again. Door shelf is usually warmer than the rest. As with most units, it takes some understanding of the air circulation pattern in order to find the sweet spots for dairy products and meat, veggies, etc. Check to see if there are slider adjustments on the drawers for temp or humidity, etc. Also make sure there are not parts missing from the inside of the fridge. Sometime a part that appears to only be a small plastic item gets broken over time and never replaced when it could actually be very important to air circulation. I recommend getting a small floating aquarium thermometer and setting it in a glass of water in order to get the "true" temp. of the products not just the air temp of the fridge. Put the glass in different locations over a weeks period to record what the temps are like in different areas of the fridge so you can make a "map" of the cold spots, etc. Leave the thermometer in for about 12 hours before you record the temps for that location. I think you will find the answers you need in order to place your food more effieciently in the fridge. As for summer days, the unit will have to work harder in warm weather to cool than it does in the winter months of course but there is always a concern that you are not cooling 100%. The way to check that is to let the unit run for several hours (turn the temps down so it runs for at least an hour solid) then you would have to pull the whole interior rear freezer panel off the back to view the cooling coils and make sure they are fully frosted across the whole coil surface. If they are iced up only in a few inches of coils then you likely have leaked out the liquid refrigerant over the years and there's not enough to cool a full 100% of its capacity. And your complaints are the same with even brand new models... it's about 60% of our service calls (not cooling properly or freezing food).
Posted on Jan 28, 2007
Fisher and Paykel N500 B fridge vegetables in vege tray are frozen
it sounds like your thermostat is not working it may need to be replaced.
May 16, 2014 | Refrigerators
Freezes produce in bottom drawer
Is the drain hole at the back of the fridge (Inside) clogged up with ice or gunk.... get rid of all the ice built up around the drain and on the bottom drawer
Dec 30, 2009 | Maytag MSD2756G Side by Side Refrigerator
Purchased in 2002 and is starting to freeze in the
Check the back of the fruit and vegi drawers. If theres a slot for an intake port try closeing it (if adjustable) Check thermostat setting for fridge and adjust to a lower setting.
Finally make sure door closes and seals closed, clean gasket with mixture of white vinegar and water (1 cup vinegar to 1 gallon warm water). If this fails internal thermostat may need replacing.
Dec 17, 2009 | Amana ARS2464B Side by Side Refrigerator
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag Model MZD2768GE
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
I have the same problem.
test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezing
see if theres a adjustiable vent close to drawers and close some... or turn down temp some
Sep 22, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Maytag MSD2756GES Side by Side Refrigerator Logo
305 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
