Question about Sony KV-27FV16 TV
Fix the piece behind the tv that the satellite cable screws into
The piece broke off of the television, and i do not know of any other way that i can hook up a satellite or cable connection.
  • 121 Answers
Rf converter connector can be replaced 50 100 est
Posted on Dec 02, 2008
Cable adapter on tv broke off
what type of connector is it? screw on? it will need to be repaired. A Cheaper option than some repairs is to buy a decoder box connect the cable to that then use the output from that to your tv scart/hdmi/component etc
Jan 04, 2013 | Vizio L32 32 in. LCD HDTV
My wife was cleaning around our Pioneer sd-532hd5 tv and she moved the tv to clean behind it. When the did, the color went awry. The sound and video is ok, just the color was affected. We have checked the...
now in the front of your tv you will see a weird piece of wood that looks like it doesent belong now its a piece of wood in the front of your tv sicured by a few screws and 2 dowels and inside you will see 2 circut bourds infront of you and a few more behind them , you will also see some connections to the botom of the projectors themselves , now you need to look to your left side and on your left you will see a little black or white casing with what looks to be 6 screws on it , but there not screws there the adjustments for your tv now just fiddle with those 6 screws til you can find your favorite color or setting and close it back up and ENJOY!!!!
Jan 18, 2011 | Pioneer SD-532HD5 53" Rear Projection...
The cable hook up on the TV broke off.
Yes...You may have to buy a new RF connector and replace. This will take some very good patience or purchase a new complete tuner. If you are not in a hurry for the tech shop. Use the rca jacks on the tv to a cable or satellite box. Just be sure when you power off you tv, that the tv is really off. A blank raster will look as if it is shut down for the time being! Good Luck!
Nov 29, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Jun 30, 2009 | JVC AV-27220 TV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connecter broke off?
It would probably cost more to have someone fix it than just replace it.If you or someone you know can use a solder iron you might get lucky and resolder conections, but most times its too hard to get at the circuit board to affect repairs and the connector usually gets mangled so bad it won't fit right anymore. Or you can try to avoid using this connection and use a different input. But you would need either a cable/satellite box or vcr (with the same kind of connection that broke on TV) and change the input used on the tv to the new connection such as 3 wire AV connection (with the yellow,red and white wires)
Apr 26, 2009 | Sharp 25H-M60 TV
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
EWF TV ANT IN BOKEN
ANGLS186-YES YOU CAN RESOLDER THE ANT. IN COAX CONECTION BUT KNOW YOU MUST FIRST SOLDER THE CENTER WIRE OF COAX TO TUNER BD. THEN CAREFULLY INSERT COAX BACK INTO ORIGINAL POSITION.THE EASIER SOLUTION IS TO USE A VCR OR CABLE BOX HOOKED TO YOUR SETS' VIDEO IN PORT AND CHANGE CANNELS W.THAT COMPONENT.JOE TV
Nov 19, 2007 | Emerson EWF2004 20" TV
Cable connector broke off at solder for GE 27GT722
Common problem Order 215543 from a company such as Union Electronics..1-800-648-6657 Use only the orginal, the replacement melts to quicky from the heat of the solder. They don't have a minimum order. Also make sure all the tuner shield grounds are resoldered. Be careful. easy to solder short.
Jun 28, 2006 | GE 25GT240 25" TV
Sony KV-27FV16 TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
