Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Whirlpool ET1CHMXKQ03 Our refrigerator is leaking water from the top. We have unhooked the ice maker and turned it off (I think) but it is still leaking. It is leaking so bad that the bottom bins are filling up with water and the back of the shelves have water on them. It looks like water is coming from the top down to the bottom because you can see water dripping from that little box that is on the ceiling of the bottom of the fridge. Any help would be great!
  • 1 more comment
  • rmoss12 Jan 06, 2009
    i have same problem..i think it has something to do with ice building up it the two spuare holes filling up with ice and not letting cold air travel between freezer and fridge. any help or ideas on this would be appreciated
  • Anonymous Feb 03, 2009
    In our fridge, the water leaks down and then freezes, forming huge ice shelfs underneath the drawers and on the various shelves.
  • Anonymous Mar 23, 2014
    amanna refrigerator freezer on top
Hello:
I also have the same problem with my ET1CHMXKQ03. Short of some serious fix, we simply found where it was leaking at the top middle and placed a dish on the top rack to collect the water. Then we emply this dish periodically. In searching the web for a permanent fix, I found the 4 articles.
Option 1:
In the center of the top of the fresh food section there is a drain cup that just plugs into the drain line at the back. Just pull it straight out and rinse it out and put it back.
Option 2:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section, from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out.
Option 3:
I had the same problem with a whirlpool refrigerator with freezer on top. TURN OFF & UN-PLUG IT. To access the freezer drain you must pull the refrig out from the wall and take off the bottom-back panel, it uses some (7) small nut headed screws. The drain is the white tube on the left going into the drain pan. You can push a long wire or plastic hose up the tube, however that will probably only hit something solid (ice) and blowing air may not clear it, until you let the freezer completely thaw out, which may take several days. I took out all the freezer items and placed them in coolers to keep them frozen. Then removed the back panel in the freezer, two nut headed screws at the top center. The bottom of this panel was frozen to the bottom of the freezer compartment, so I used a hair-dryer to thaw it enough to loosen it. (Be careful: water and electricity do not mix well!) The left side of this panel has some electrical control wires attached, so the left side will not come out, just rotate the panel and lean it against the left side of the compartment. Now use the hair dryer (or pour hot water on it) to melt the ice along the bottom back of the compartment under the freezer coils. BE CAREFUL: The fins are sharp and will cut! Do not bend them. If they are all frozen up your heating element-defroster may be out. If there is only ice along the bottom, the hair-dryer or hot-water will help melt it to the point it can be removed. If the drain hole at the back-bottom-center-right is plugged with ice, poor hot water on it to speed up its melting. The hair drier will not do this very fast and you cannot chip it out without damaging the plug hole. Mine was solid ice about 2 inches into the tube and hot water finally thawed it. Then pour water through the hole to flush it out. Clean the bottom drain pan & re-assemble. Good luck.
Option 4:
You have to turn fridge off for 24 hrs . Because the drain hose goes down to the drain pan , it goes between the walls. So you cant access it to clean it out Get a small hose and push It up the drain tube from the bottom ,and blow Up the hose to clear the debris
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Posted on Feb 05, 2009
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
How can i check to see if the defrost is working in my whirlpool refrigerator model number ET1CHMXKQ03. Initially water started leaking into the fridge from the freezer, i looked and saw everything iced...
you will need to access the heater in the rear area of the freezer compartment and disconnect the heater element and take a continuity test of the element,if this checks good,then in the same area is your defrost timer,unplug the heater from it and hook up a voltmeter and energize the defrost timer manually and see if you have a voltage there
Jan 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
The ice maker doen't make as much ice as before in the ice dispen
level the refrigerator. water pressure may be too high 65 psi max. check if there is a chunk of ice stuck, diverting the influx of water, cubes should not exceed 7/8 in thick or tall at widest point. no axel mark on top. fill should be no longer than 7.5 seconds.If longer then 7.5 sec, replace modual
Aug 24, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking into the fridge. I think it is coming from the ice maker. If I turn the ice maker off inside the freezer, then the water problem is worst. So, is there a way to cut of the supplier of...
There should be a cutoff valve on the line going to the fridge. This will cutoff water dispenser, as well, if it has one. It may be behind the fridge or under the sink, or???
More help?, let me know.
May 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
check first if there is water coming in the ice maker.
check the water solenoid at the back of the fridge. check the water line if there is water coming to the solenoid.
if you have filters installed, check the water coming out of the filter. it could be clogged.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Temperature control
hiya
the thermostat should be inside the fridge compartment usually near the light.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 03, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Feb 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
2,571 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
