Question about Samsung RS2630WW Side by Side Refrigerator
Broken water line
The water line that goes up into the refrigerator has got cut into, How do I replace it...
  • 237 Answers
Please repost with more description as to where the line is cut. Do you know if it's the line for the ice maker or is it the line for the door water, etc.? How long is the cut? Can you see the cut in order to repair it or is it deep inside the cabinet? It is usually easy to "fish" a new plastic line in but there is normally enough slack to cut out the damaged part and use a quick connect to splice the line back.
Posted on Jan 28, 2007
Brittle and broken water line at water valve
No way unless you want to poke holes in unit and possible affect the integrity of unit. Not recommended.
Sep 06, 2017 | GE Profile 23.3 Cu. Ft. Counter-Depth...
How to replace the water line inside the door, it was punctured during door removal and the hole is right at the point it goes inside the door. please help.
Order a new line for your model and use the old line to pull it through the door. Cut the head of a screw off and use it to connect the old line to the new water line to help pull it through.
Aug 03, 2011 | Samsung RS2630SH Side by Side Refrigerator
Plastic water pipe is broke behind refrigerator. when the water dispenser is used, water goes everywhere. what is the best way to fix the line
Hello, Thank You for using FixYa. I will be helping you today.You can replace the whole water line or cut out the broken section and use a coupler to connect the hose where you cut out the damaged section. You just push each end into the coupler and your done.
you can get the line or the coupler here http://www.repairclinic.com/Whirlpool-Refrigerator-Hose-Tube-Or-Fittings-Parts
Thank You and please rate my answer if it was helpful..
Jun 28, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Water dispenser line is broken at connector end in the back of the refrigerator. Pieces of the broken pipe are glued inside the connector. Can we buy a new connector and glue it to the existing pipe? If...
The connector is a push on . Push in on the ring , while pulling out on the broken plastic line . Cut the end of the existing line , and just push into the connector snugly . Uses no glue or adhesive .
Nov 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore thru door water supply hose broken at bottom hinge
if there is enough line cut the broken piece and connect a union right there. if not the line through door needs to be replaced. it shouldnt be too hard to replace.
Nov 04, 2009 | Kenmore Refrigerators
Regrigerator water pipe is broken
refrig's only use 5/16 or 1/4" dia. lines. you can cut and splice the broken line if you can find a 5/16" X 5/16" quick disconnect coupler. homedepot only carries 1/4'. try your local plumbing store.
Jul 14, 2009 | Refrigerators
Water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Jul 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice works but no water comes out. when you press the water dispencer the waterleakes on the floor. I've been told I have a broken bladder, but I don't know where to locate it? Nor how to replace it.
Remove the toe kick, on the t side you will see a connector where two water lines meet, if the water is leaking there, push the two lines into the connector and then pull back on them to make sure they are sealed. test to see if it still leaks, if it does push the red or blue ring around the line in, while doing that pull the line out of the connector, repaet for the opposite side. use a razor or sharp knife and cut about a half inch off each line, make sure they are flat, push them back into the connector, and pull to seal, if it still leaks replace the connector. If the wateer is coming out of the freezer door replace the water line that goes through the door.
Jul 07, 2008 | Frigidaire FRS26R4A Side by Side...
Samsung RS2630WW Side by Side Refrigerator Logo
395 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
