Question about Dishwashers
I have a ge nautilus dishwasher and i took the door panel off. Problem is the spring popped off the timer and I do not know how to put it back so that the cup closes that releases the detergent. My wife is upset and I need some type of help. A diagram anything I am searching the net but to no avail. Please help. Derrick
  • Derrick M Dec 02, 2008
    Hi, this is Derrick again the model to my ge nautilus is gsd2600g00cc. Ive tried to use the links that you provided but im not sure what im looking for. I tried the diagram but it doesnt show where the spring is attached to other than the white lever. I guess I just need to get a look at the complete assembled timer with all the pieces hooked to it or something. Again thanks for helping in my obvious time of need. If there are any links that you may know where I can get a pic of the assembled part or a tutorial anything will be greatly appreciated.
    Thanx,
    Derrick
  • 706 Answers
Hello Derrick,
I learned a long time ago that a picture is worth a thousand words and that before attempting any repair, I typically take several digital shots as a backup and in case I forget where things went. I know that won't help you now but it may in the future.. Especially since digital cameras are so cheap.. I'll poke around and see if I can find you a shot for you to use as a reference but you may be better off going to a local appliance repair place and pose the same question ..If you are lucky.. they will have something to look at and I would take pictures too. ( BTW: I have one of those wives too..LOL) see if this link helps you my friend.. http://www.pcappliancerepair.com/model-display.php
Item #837 is the spring.. hopefully that will give you enough to get you thru it..
Regards
Rick
Posted on Dec 02, 2008
  • 706 Answers
Hello darawsin,
Since you didn't specify the particular model number, it is difficult to provide you with specific details. Please use this link to the GE website to find product information... http://www.geappliances.com/service_and_support/literature/
Here is an alternate site that may help you too.. but .. you will need to provide the specific model number for any detailed information..
http://www.pcappliancerepair.com/ge-dishwasher-parts.php#books
Hope this helps..
Regards,
Rick
Where are the fuses in the nautilus dishwasher
I do not believe there are fuses inside the dishwasher.
When the Use and Care Manual mentions a fuse (Fuse is blown, or the circuit breaker tripped), it is referring to the Fuse Panel/Circuit Breaker Panel.
What problem are you experiencing?
Dec 31, 2014 | GE Nautilus 24" Built-in Dishwasher
When I took the timer off of the door to replace it, a white lever that connects with a black lever which both together help open and close the soap door came off, along with a spring. I can't for the...
Explanation I am afraid may not work right unless you calm down and sit in fron of te unit with the lever and spring to be pushed back to the slot. This is the triger for the soap dispenser when the timer come to this program- it initiates the lever to dipense the soap. So use logic with time and you CAN do it if you can replace the timer. However if this is not there that function will not work and hence the cleaning may not be good.
Imagine the function,and piece the items to put the puzzle right.
The lever is for the link to open and the spring for it to come back.
Hope this helps . Good day
Aug 18, 2010 | GE Nautilus 24" Built-in Dishwasher
Door of soap dish does not open
spring broke of fell off inside the door by the timer have to take the door apart
Dec 05, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't start
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
May 30, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus detergent cap will not open
Sometimes these get gunked up and need to be coaxed....so take a butter knife...insert it in the edge of the dispenser tray...pry gently...all the while turning the timer control knob...it should pop open at one point if not try a little more pressure...and once open .clean thoroughly..if it persists you may have a timer or control panel issue...also use factory recommended soaps...
I hope this helps...Good Luck and Good day....thank you for rating my effort.....The Fang.
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Having trouble putting door together
Whenyou took the door apart did you take note of how so you can reverse the proceedure Sorry it is difficult to explane in words on how to put a door together all I can say is try placeing the panels from the top down and bottom up then if anything works put in all the screws halfway then after all the screws are in then tighten them as evenly as possible
Jan 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Nov 09, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher - The soap door is stuck partcially open
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
Jun 27, 2008 | GE Nautilus 24" Built-in Dishwasher
Need Help !!!!
This is pxl8tr and I solved the problem by cycling the timer through, and the geared timer linkage automatically aligned with the soap dish!
Mar 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
