Question about ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Fan will not work
I have a a7vbx-x motherboard it was working fine i just needed to mount a fan my brother messesd around with it and changed the little blue jumper switches . nowmy fans do not run they light up but thats it . my comp still works just no fans . what should i do to fix it?
  • elliottdavid Dec 02, 2008
    well i understand plugging in the the fans . they are plugged in as for witch shorting cap , usbpw , keyboardprw and chassis are open he took them off . i went through diagram and tried to find witch ones should be capped and how like 1,2 2,3 and so on if you could mabey give me a step by step of what setting to have all the caps on to work i could easy do it. and could this cause my fans not to work?
  • 64 Answers
I found the manual for your board. it will show you diagrams of board along with all the jumper setting. THis is what the doctor ordered. PDF file online at this address: http://dlcdnet.asus.com/pub/ASUS/mb/socka/kt400/a7v8x-x/e1198_a7v8x-x.pdf
took some time to find, if it helps, please spend the time to rate this answer. good luck
Posted on Jan 27, 2009
  • Mr-Sticky
    Mr-Sticky Jan 27, 2009
    like i had said in my first answer to your question, the step by step is in the MANUAL on the site that i had mentioned. it has diagrams, picture and text to guide you. It took me some time to find the site, would appreaciate if you could take time to rate this solution.
    thanks and good luck.
    Genius:
  • 1,605 Answers
The fan should be plugged into the 3 pin socket between the CPU and the RAM.
if the fan already in the right place, please let me know which shorting cap got moved.
Posted on Dec 01, 2008
Cpu fan not working
If the CPU fan is actually spinning (make sure you're looking at the right one - it should be the fan mounted directly onto a big circular heat sink near the top of your motherboard), then it sounds like your mobo has a faulty sensor. If it's still under warranty, get it changed for a new one.
Mar 09, 2010 | HP Computers & Internet
Reformat
Here is a link from Asus:
http://support.asus.com/download/download.aspx?SLanguage=en-us
You can find drivers for what you need in the link above
Feb 27, 2010 | ASUS P5GC-MX/1333 Motherboard
Asus a7vbx-la not supporting sata 500 gb
Are you running the latest motherboard firmware revision?
Dec 29, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
I need ASUS A7VBX-MX SE Driver
Just got to http://support.asus.com/ then go to drivers downloads. select your motherboard.
Sep 23, 2009 | ASUS A7V8X-MX SE Motherboard
I am looking for a manual for motherboard model a7vbx-la
is it the A7VBX-LA and not the A7V8X-LA?.
This is not a TRUE Asus motherboard,It is a motherboard that HP contracted Asus to make. but here is some info that should help you.
http://www.mxdatarecovery.net/asus-motherboard-socket-462--a7v4627.html
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&lc=en&cc=us&dlc=&product=436281
Jul 20, 2009 | ASUS Computers & Internet
Wanting two harddisks to work
You need to change the cap that covers the pins on your drives
Most of them have the way to put them on the instruction booklet or printed on the drive.
Hope it helps!
Jun 27, 2009 | ASUS K8V-VM Motherboard
AUDIO DRIVER /M.BOARD A7VBX-X
The motherboard may be the ASUS A7V8X-X (not A7VBX-X); the audio driver is available on the ASUS site.
Mar 22, 2008 | Asrock ConRoe1333-D667 Motherboard
ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard Logo
139 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
