Question about Whirlpool AWM5145/2 Front Load Washer
Faulty timer/washing machine model is whirlpool 1400 awm5145.
When i set the timer/programme it just continues to go round and round and only works when it wants to.
SOURCE: bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
Posted on Jun 11, 2008
  • 97 Answers
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Posted on Aug 06, 2008
  • 3 Answers
SOURCE: very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Posted on Dec 06, 2008
  • 82 Answers
SOURCE: Bosch Excell washing machine programme fault
yes it can be but get in an expert to check it might just be the heater element and brushes
Posted on Jun 28, 2009
  • 5911 Answers
SOURCE: why my whirlpool washing machine wont spin model # LXR5432KQ0
If this is a Whirlpool manufactured TOP LOADER washing machine, a no spin problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem and repair it yourself:
Read through the link provided and let me know if you have any questions. I have included parts resources and instructions on how to replace each part as well.
The part number for a replacement lid switch is 3949247. The motor coupling part number is 285753A.
If you have questions, please post back and let me know. I hope you find this information helpful.
Posted on Apr 14, 2010
check if water pump dont release water properly..u can see that in the end of drain hose ..fill the washer w/ water then set it to spin after that look the hose if the water flow properly..
Mar 08, 2014 | Whirlpool AWM5145/2 Front Load Washer
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
I have a front loader model 850 (4.5 kg.).I select programme #5, load the machine and initiate wash cycle. Water is introduced for a few minutes but programme does not proceed. Machine remains...
I just love the way you write. I can tell you are not from the U.S. lol. more than likely your timer/controller is faulty . The little motor than turns it inside is broken.
Oct 29, 2010 | Whirlpool Washing Machines
Programmer sticks before the spin cycle (number 5 and 9) on my beko washing machine also if you change programmes the programmer jumps round
Prog jumps as it will carry out 1st command selected unless reset.the sticking could be a faulty water solonoid valve if this happens say during softner fill although could also be the timer /programmer at fault
Apr 03, 2010 | Washing Machines
No hot water whirpool awm 321/3
A faulty inlet valve solenoid on the hot water side could be the cause. The solenoids can be tested for continuity using a multimeter or ohm meter. A lack of continuity indicates a faulty solenoid. I am attaching a photo for reference purposes. Hope this helps and best wishes.
Aug 03, 2009 | Whirlpool AWM5145/2 Front Load Washer
Machine wont complete a cycle, it clicks once then stops
try to preceed manually to next program and if this problem repeat then the timer has problem chang it my advice donot try to select program during electricity connected to timer thank you
Jun 07, 2009 | Whirlpool AWM5145/2 Front Load Washer
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
My washing doesn't smell clean? Help
the drain water pump its not working properly , needs to be cleaned the drain hose needs to be check for posible bent or clogged , ,please be sure that the drain hose ,and drain pipe are installed ,no more than 12 inches above .of the machine, and avoid long hoses. let me know thanks
Jun 20, 2007 | Whirlpool AWM5145/2 Front Load Washer
Set the programme first, & then put the on botton on.
Apr 07, 2007 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
