Question about Sony KP-53XBR200 53" Rear Projection Television
Kp-53xbr200 SONY video shuts off but sound stays on
Hello, After 10 minutes of watching the TV the video shuts off and the sound stays on. Any suggestions
  • 1 more comment
  • Mdcecu Jan 22, 2008
    Same issue...trying to determine if we should fix it.
  • Anonymous May 10, 2008
    after a while video shuts off but sound stays on light timer and standby flashes
  • joelvartv Apr 17, 2009
    i have tv whit thew same problem only the red led is blinkink 6 times
    Sergeant:
  • 308 Answers
Sounds like a bad solder connection. When you lose video, does the on screen display still work, and if so how about your picture in picture? If no OSD or PIP works then you may be loosing your High Voltage to the picture tubes. Some circuit board assemblies are no longer available from Sony for this model so you may be out of luck if the problem is more than a bad connection.
Posted on Jan 28, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Colors are separated, double vision in lower right corner.
Oh, yea - another misaligned projection TV. All rear projection TV's seem to eventually get this disease.
Fix: perform a "convergence," which will converge all 3 color projectors to the same point.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Dec 11, 2010 | Sony KP-53XBR200 53" Rear Projection...
Center light out and alignment may be off I see semi circular lines on screen in video mode
Ur convergence is dead,U now how to solders?Tries Tv repair World.com,Tvrepairkits.com.
Dec 25, 2009 | Sony KP-53XBR200 53" Rear Projection...
How do I stop from getting double pictures on my KP-53XBR200 53 in? And Stop the color green from going of center with the rest of the other colors?
Could be a convergence adjustment from your remote under MENU. (This can be done by you)
Could be a problem in the convergence circuitry. (This can be done a TV tech only)
N Sabre
Nov 07, 2009 | Sony KP-53XBR200 53" Rear Projection...
Sony KP-61HS10
Five blinks is a video abnormality detection and I am all too familiar with this repair... One or more of the crt's in this unit has a bad set or failing guns in it... You can have a local tech bring out a crt tester and rejuvenate the tube for a temporary stay but it will eventually fail for good and in a short period of time it will be one or the other - - VERY expensive to repair or off to the dump...
Please don't kill the messenger!
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Sony KP-61HS10 61" Rear Projection...
SONY rear projection TV - Whites have started looking "snowy"
This is your Picture tubes getting very weak.( low in emission ) You have three in there and I guarantee they are no longer available so I would start thinking about investing in a new set, but use that one until you can't stand it anymore.
May 28, 2009 | Sony KP-53XBR200 53" Rear Projection...
Blurry image
maybe a dvd setting
try an other device in the inputs to verify its not the dvd
if you get a good picture through cable input then
component inputs (should be good)?
Dec 20, 2008 | Sony KP-53XBR200 53" Rear Projection...
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Kp-57ws500
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
May 01, 2008 | Sony KP-57WS500 57" Rear Projection...
Long time to power up video
My Sony KP-53XBR200 will not display any video (even from the tuner) except the internal display until it sees a video input on one of the video jacks on the back after a power hit.
I solved this by putting a video cable from Monitor out to Video 4 in (unused for other video). Voilla! Instant video on. This may not be your issue, but it fixed my set!
Oct 20, 2007 | Sony KP-53XBR200 53" Rear Projection...
Sony KP-53XBR200 53" Rear Projection Television Logo
98 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
