Question about Durabrand WD810
Gum stuck in car cd player
I accidentally put in a cd with gum into my car cd player. I discovered it when it wouldn't play and then ejected the cd from the player. Is there a way I can clean the gum from the cd player?
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
Hi, my CD player is busted in my 2006 Malibu Maxx LT V6. My CD player won't eject the current cd I have in it, but is still capable of playing the stuck CD. Is there anyway I can get it out?
i have the same problem!!! what i do is press eject i put the key in the cd slot and turn it sideways....and then a pair of tweezers easily fits in there and you can get it out. then to play a new one you have to put the cd in and press down on it with your ever so handy chevy key!!!
Jul 14, 2010 | 2006 Chevrolet Malibu Maxx
The CD player/changer in my car is not loading or ejecting the CD's. When I push the load or eject button, it makes a grinding sound. It was playing fine yesterday but since I left a CD inside the CD...
I just acquired the same problem. I tried to put a new CD in and it wouldn't take it. I ended up pushing it in when I was trying to get it back out and now it won't play the CD, or eject it. I think it could be stuck between tracks, but they want $188 to look at it and fix it even if it is a simple fix. I am looking for suggestions also, Diane
Mar 13, 2010 | 2003 Mazda Mazda6
CD is stuck and eject button doesn't work
Unplug the cd player and open the unit up by taking the top cover off..there will be screws holding it on on the underside. You should be able to retrieve the cd from inside. Your track is broken, you will need to replace it.
Jun 01, 2009 | Pioneer DEH-P3100 CD Player
CD player won't work
it may have another stuck CD inside. or something else. Especially if there are kids around. I removed 2 CD's from a stereo which had the same problem.
Apr 08, 2009 | 2004 GMC Sierra 2500
DVDS stuck in overhead DVD player
the motor will not be strong enough to eject. you can try the emergency eject hole with a paper clip . just push straight in and the gears will began to turn so push straight in a couple of times and it should began to eject.
Dec 13, 2008 | Jensen 8.5'' Overhead DVD Player Package...
Cd stuck in my Dual XD5120 cd player in my car.
if the cd player has failed about the only way to retrieve the disc is to take apart the player
Jun 20, 2008 | Car Audio & Video
Cd is stuck
put the same disk in , play it for a while then eject it properly.
Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
Cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Jan 14, 2007 | Kenwood KDC-3027A CD Player
Durabrand WD810 Logo
23 people viewed this question
Top Durabrand Car Audio & Video Experts
matt martin
matt martin
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
