Question about SimpleTech SimpleShare 250 GB Network Hard Drive
SimpleShare not so simple!
Hi. It's a long story but I'll make it very short. I'm having installation problems. I cannot access the drive by typing \\SimpleShare. I get an error message "Windows cannot find". I also ran the NASFinder and it did find SimpleShare but it fails to map drive and returns an error message "could not mape drive! Error=53. The trouble I'm having is identicle to this persons experience: Please help. Any suggestions? Thank you.
  • 624 Answers
Re: SimpleShare not so simple!
Some questions first.... You didn't mention anything about your home network. Details about: -what specific router you have. -The LED status of the router port your simpleshare drive is plugged into. These drives are fairly simple to use IF they connect to your home network correctly.
Posted on Jan 28, 2007
I know for a lot of people that this problem is fixed by going into the advance menu, selecting the Printers button at the top, and changing the printer pool from Simplepool to No Printer Pool. You should then be able to map the drive in Windows. You can then restore the Simplepool printer server if needed later on for any usb printers you may attach. Good luck.
Posted on Feb 03, 2007
0 characters
3 Points
New computer'-5'2LCpR5QN2T/IFS1nmGn0Mm0h/Wc4RSwSaUFFckjxuZ8UfQCzT3UQg1uMJfIyzAGn7vwxm8LQ0MKbzeWz8o3BZ6698VuCEIBu0wiEOq/UxFd6cegHa2g==
Apr 30, 2014 | SimpleTech SimpleShare 250 GB Network Hard...
I have a problem with Verbatim MediaShare Mini. I have connected a USB Drive. I cant delete files on it because I dont have permission to do. How can I change permission to delete files? Thanks.
MediaShare Mini - Verbatim 97329 - Home Network Storage -- AVOID THIS PRODUCT -- it is not a real solution to simple home networking [network drives] needs nor are there fixes to multiple problems and issues.. Must have #coded installation disk and connected to internet. Security issue - must allow 3d party access to your Home Network via internet. It is designed to work with Verbatim.COM web-site for additional monthly fees (not disclosed up-front/prior to purchase). Customer service is off-shore non-responsible, not knowledgeable, not "good communicators" -- emails requesting help are ignored. I have yet found any success stories in fixing the problems --- also I noticed it get very HOT on the bottom which concerns me for electrical product that is to be left on 24 hours a day....
Jul 11, 2011 | Verbatim 97329 MediaShare Mini Home...
Iomega media network hard drive not accessible
Use this file recovery program called asoftech data recovery:
You can find it in magazines or on a internet...
It is a simple, fast program which thorough scan the computer, which allows you to recover lost files
May 03, 2011 | Iomega Home Media Network Hard Drive 500...
Belkin N+N storage router doesn't work wirelessly
Hi, I had something like that with my Belkin Router N+N with USB F6D6230-4 V1, only I had a configuration wit a wired XP pc, Wireless XP and Wireless Vista. With both XP pc’s it was really plug and play, but with the Vista pc I had some problems to access the on the router connected USB drive. The Vista pc was connected to the network, and had Inet access. Other shared (network) drives were accessible on the Vista pc.
The first thing I tried was if I could access the drive trough its IP address, (\\routerIP in my case \\, and I did get a question for a username and password. The only thing is that I tried all the regular names like Admin, Administrator, and so on, with my password but I did not get access.
On the internet there was no help to find for this model router on the Belkin websites (diverent country’s), the data on the Belkin websites is out of date, there is no support to find for new models. ………. So finely I did took the phone and did call the support desk…
Solution to my problem:
The problem seems to be in the Belkin storage manager program, that program works not correct under Vista. When I enter the routers IP and use the username “guest” without a password, it get access to it from my Vista pc. The follow thing I did was press the right mouse button on the drive, and press on “make connection” So..
Username : guest
Password : none
Hope, that this is also the solution to your problem.
The Netherlands.
Feb 23, 2010 | Network Storage Systems
Computer doesn't recognize drive
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Jul 11, 2009 | SimpleTech SimpleShare 250 GB Network Hard...
Cant able to access the 1tb network storage
Consider a few things that may solve the problem:
1. this is how I always like to test; shut down the NAS drive for a minute and reboot; once rebooted see if it is accessible
2. need to know the ip address of the NAS drive and make sure that ip is not blocked by your system firewall (e.g. add that ip into trusted address on the firewall program; or temporarily disable any anti-virus or firewall and see if you can access, and if you can then it is the issue of firewall),
3.unless you have customized the settings, open my computer and on the addressbar type type the ip address if you know (if it is WD Mybook World then you can also try typing \\mybookworld on the address bar); in this case also try it by temporarily disabling any anti-virus or firewall program
4. one way you can figure out the ip for your nas drive is through the router's homepage; since I don't know your router type I can't give you specific steps; but try to get onto the router's main page and see the client's list or DHCP Client's List or something similar where you should see an ip also assigned to the NAS drive which is connected to the same router.
Post the feedback what happens... we'll see... good luck !!!
Jan 09, 2009 | Western Digital My Book World Edition 1TB...
Problems with Western Digital My Book World Edition
I have the same drive. It works great with windows XP but with Windows vista has difficulty seeing this type of drive and keeping the connection once it is established. Take it back if you have windows vista and then search for which 1TB drives work well with windows vista. It really has problems with windows vista 64bit. I was able to finally see the drive when I was using photoshop file/browse/network... then I dragged the shortcut Icon to my desktop and access the drive that way from that point on. Mine stopped completely tonight... I think the power cord went bad or something.
Jan 04, 2009 | Western Digital My Book World Edition 1TB...
Need to install 1G ativa flash drive
If this is a USB device and you are using Windows XP, you do not need to install a driver. The driver comes with Windows XP and the device just work when you plug it in.
Feb 02, 2008 | Network Storage Systems
Cannot Access Shares
Log on the computer to "administrator" account both system will see each other. To do this:
when computer prompted to type your password , Simultaneously press" Ctrl+Alt+Delete" 2 times and you'll prompted to type the username: Just type "administrator" and then enter(note: applicable if the the administrator username has no password.)
any problem regarding the solution please notify me for further information.
Jan 07, 2008 | Buffalo Technology HD-HG400LAN...
SimpleTech SimpleShare 250 GB Network Hard Drive Logo
3,198 people viewed this question
Top SimpleTech Network Storage Systems Experts
Daily Mehdi
Daily Mehdi
Are you a SimpleTech Network Storage System Expert? Answer questions, earn points and help others
