Question about Belkin Computers & Internet
Wireless network ok but cannot connect to internet from wireless adapter. Was working but now i cannot access the set up disc. No internet or modem lights on router ?
  • jockeyjoc May 11, 2010
    What Version is your adapter, Router and Modem?
    Genius:
  • 1,061 Answers
Direct CONECT TO INTERNET AN DOWNLOAD DRIVERS AFTER UNINSTALLING OLD DRIVERS. REBOOT AND SYSTEM WILL SEE ADAPTER AND LOAD DRIVERS FOR SETUP.UNPLUG ADAPTER UNTIL DRIVERS ARE LOADED RICHARDM69
Posted on Dec 02, 2008
Won't Connect to the Internet
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers.
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled, If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake
Feb 10, 2013 | Gateway LX6810-01 PC Desktop
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
My desktop an Acer Aspire Z5600 will not connect to the internet, my internet provider Hughes net has said that their modem is working properly. I have run trouble shooting on my computer and get a me
Hope this helps.
Dec 21, 2012 | Computers & Internet
I hooked up my D'link to modem and computer and connection is good. But i can't find it when i search on laptop wireless connection. I think you need i driver but i can't find one. Thank You
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
B52Computers
Jan 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Router -> Modem Connectivity: I am fine if I'm hard-wired to the modem but if I connect wirelessly through the router I can't get WAN. I can get the modem page wirelessly. This just started tonight. I...
Have you check your DNS settings within your Wireless Network Adapter TCP/IP properties settings? Or it may be a proxy server or firewall settings wich may block internet access to the internet. Try testing it with your LAN cable first and see if you are able to connect to the internet using that cable from the laptop/pc to the modem. If it works using the network cable then it might be a DNS related issue on your wireless network adapter tcp/ip properties.
Jul 29, 2009 | Belkin (F5D5231-4) Router
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
Apr 29, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
Oct 29, 2008 | Computers & Internet
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
HELP PLEASE ASAP
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Sep 15, 2007 | Actiontec GT704WG Wireless Router...
Computers & Internet Logo
62 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
