Question about Dryers
Whirlpood dryer Model LER8620pwo Above dryer will not start. I've checked circuit breaker. I disconnected door switch thinking that would be the same as shutting dryer door; therefore, starter switch would work if problem was door switch. Starter switch does not work. I, also, checked outside to see if vent is open. I appears to be open. How do I get to location of fuse? Do I check starter switch by checking with meter across top of switch? Blue wire to pink wire to see if I get a reading? Thanks, Gar and God Bless!
  • jesuslovesyo Dec 09, 2008
    Hi Mike, I'm sincerely sorry that I hurt your feelings. Try to understand what your information stated. You didn't say to check the fuse first and then check other things. You said that the thermal cut out was the part that I was looking for. I knew the cut out was ok because I checked it with an olm meter. I know little about these things, however, I knew it would have to read across to be ok. I thought from the beginning that it was probably the starter button. However, in my ignorance I thought it was alright because it was showing a reading. When I checked everything and all items was reading on the olm meter, I took it to an appliance store where the starter button was checked again by a technician. The starter did read, but it was not reading accurately. And that was the problem. I guess you realize that two other people sent me an e-mail. Neither one of them mentioned the starter button, either. I realize that you guys are at a disadvantage not being on the location of the problem. When I gave the rating I was not angry, I just thought that the "thanks for trying" rating was the most accurate. Try to understand that when people, like me, e-mail for help, we are probably very ignorant about the problem. We need detailed step by step information. Looking back, I can understand that checking the cut out would be the first thing to check, but if it is ok where do I go from there? Think about it, again you told me it was the cut out. I could have sent for it and waited some time to receive it, only to find out that it was not the problem.
    Again, I certainly didn't intend to hurt your feelings with my rating. The positive in all of this is that I took the dryer apart to look at the motor. I'm 68 yrs. young and have always wondered what a dryer looked like inside. Now I know! Hang in there and I will be praying for you to do well in your business! God Blessings on you and your family!!! Gary
  • candlelite Mar 09, 2009
    My cycle thermostat was bad. I had pulled the wires and taped them together. Orange to orange and violet to violet. The dryer worked alright. At some point it quit working with the wires jumped. I held the start button down and turned the dial. The violet wires arced and there was a buzz inside the dryer. I then replaced the cycle thermostat, and now it won't start. I did get it to repeat the whole arc and buzz thing and it threw a breaker. With the new thermostat in, it won't even hum. Got any clues for me as what I have done?
  • 172 Answers
Pull the dryer out and unplug. At the bottom left of the back you will see your blower housing. on it you will see a 1 inch by 1/2 inch white thermal cut out. This is the part you are looking for. it is part number 3392519
This part is available and cost$18.00 to ship it to your door.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
  • Michael Anderson Dec 09, 2008
    Thanks for the poor rating, I told you where the fuse is located on the dryer. You should check it first, then research other possibilities. Why give me a low rating. I am sitting at home taking time away from my family to help people for freeeeee. Thanks alot.
  • Michael Anderson Dec 11, 2008
    Gary,
    The question you asked was. "I, also, checked outside to see if vent is open. I appears to
    be open. How do I get to location of fuse? " To that I answered the question you asked. You also did not state you had checked the fuse with a olm meter. Had you stated that I would have directed you elsewhere. If you had already checked the fuse, why did you ask its location? If you want more detail, why did you not include all the detail you had available? My 20 years of working on dryers told me you were not clear as to the problem you were having and knowing the part was very inexpensive and easily replaced and also it is the cause of this problem 90% of the time. A $10.00 part was not much of an expence. My labor rate is $60.00 an hour and I have given you atleast that in my time typing to you and looking up your model and researching your part numbers. I have done this not for money, but to help another person. In return you can click a button to rate the free service I have provided to you. It is as easy to click the 1, 2, 3, or 4. What do you do for a living good sir? Would you take the time to do that for 1 hour for me for free, then expect a 2 of a possible 4 in return. This has mame me deside that helping other people is not worth the time. God bless you and your family, do not expect me back on this site as I see my time will be better served helping my family and not strangers around the world. Understand that.
Dryer
test this steps and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#electric#ixzz2Zk5oxDiH
Jul 21, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Amana Dryer Model # NED4500VQO won't start
see the following steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-1#ixzz2Yb4M1zkU
Jul 09, 2013 | Dryers
70 Series Dryer will not start. Checked breaker box. Unplugged unit and checked connections and cleaned out built up lint dust. Door is sealed properly and light inside dryer is still on when door is
Check the motor for a blown fuse or circuit breaker attached to it, maybe a wire is disconnected from it. Another thing to look at is the actual switch on the top. Is it making good contact? Does it have a fuse or circuit breaker attached? Is it getting power?
Jan 11, 2013 | Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
My whirlpool dryer will not start
OK, check the following areas to combat this no start issue.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
If all the above checks out ok, replace the timer or control board.
Jun 14, 2009 | Whirlpool LER5636P Electric Dryer
Frigidaire Crown dryer will not start. Has power to it
Check the following to address this issue.
Jun 11, 2009 | Frigidaire Electric Dryer
DRYER DOES NOT DO ANYTHING
Jun 02, 2009 | Maytag PYE2300AY Electric Dryer
Estate dryer wont engage
Check the following--
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer is getting Power but not coming on.
Check the following---
Jun 01, 2009 | Roper RES7646KQ Electric Dryer
Dryers Logo
420 people viewed this question
Top Dryers Experts
