Question about Xerox Phaser 6180N Laser Printer
Xerox phaser 6180n :erorr msg 1) "motor erorr" 2) "error 042-325"
Followed xerox instruction to 1. turn off 2. waite 10sec 3. turn on. This did not work.
  • Anonymous Feb 03, 2009
    same problem, and can't find error message in the manual!!!
  • 2,072 Answers
Your main drive motor is either not statting or the main board is not sensing it. You can remove the covers, WITH THE MACHINE UNPLUGGED !!!!!!!!!!!!!!!! and reset all the connectors, check the drive motor, and see if maybe a gear is broken., If the machien is less than 1 year old. Call 1-800-835-6100. You will have some kind of 1 year warranty, Either on site or in depot repair, which would mean they will ship you a new machine with a box to return the one you have. If you call, make sure you have the serial number handy so it can verify the warranty.
Posted on Dec 02, 2008
Need Error codes for a Xerox Phaser 6180
What exactly are you asking for here?
Best regards,
Jun 20, 2014 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 6280 Y CRUM ERROR
The yellow cartridge either has a corrupted chip, or the wrong chip, or its a cartridge from a different model of printer.
Xerox 6180 and 6280 cartridges LOOK the same, apart from the label and part number - the chip is different.
Feb 08, 2013 | Xerox Phaser 6180N Laser Printer
ERROR 093-951
see this page for detail and how to repair
i hope this helpfull, if you think this helpfull please rate very helpfull
thanks for using fixya
Jan 23, 2011 | Xerox Phaser 6180N Laser Printer
After sending a fax I would like a confirmation page
Xerox phaser 6180N is not a "combo" device but a printer alone.
You should check with your fax software how to print confirmation pages.
Nov 10, 2010 | Xerox Phaser 6180N Laser Printer
The Xerox Phaser 6180N Laser Printer won't let me print only black if the other 3 colors are empty. Is there something wrong and is there a away to fix it?
These printers need to 'think' they have a full set of useable (ie not exhautsed) cartridges.
There are two solutions.
1 Obvious really - replace the 'empty' cartridges - good quality remanufactured ones are available these days.
2 Replace just the chips on the cartridges (much cheaper than replacing the cartridges. There may still be some toner in the cartridges, and the colours may print for a while, but this is really only either a stop gap solution, or OK if you ONLY need to print in black.
Apr 09, 2010 | Xerox Phaser 6180N Laser Printer
I have a Xerox Phaser 6180. I have not had any
You more than likely need to place a service call.
Over temp can be related to the fuser control circuits,
Dec 15, 2009 | Xerox Phaser 6180N Laser Printer
I have xerox works center pro photo copier model 5225 it is given error code 042-325 please help me
That is a main motor speed fault. You can try turning the machine off and taking the drum unit out and putting it back in and powering the machine back up.
You can pull the main drive motor and see if it is just sticky on the shafts, if not, replace the main motor.
Dec 13, 2009 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 8560MFP/N System error 09,038.46:950
Hi mary_ballling:
Here is you problem.
9,035.4x through 9, 038: Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to Step 3.
Remove any blockage and/or replace the ink stick.Run
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run
Hope this helps
Jul 31, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox phaser 6180n
Sounds like the memory stick is loose.
If you just received it, that machine has a one year warranty on it.
Call and Xerox will send someone out, or else they will replace it.
Your going to love that printer. WOW what print quality it has.
But your problem most likely was due to shipping and something coming lose.
Call 1-800-835-6100, follow the prompts, they will help make it right.
Jul 11, 2008 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 6180N Laser Printer Logo
1,153 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
