Nearly every time I try to log-on to AOL I have to press the button on the back of my BT 190 Voyager ADSL Modem and take the power button out,then re-plug it before I get the modem to work. Do I need a new modem?
    Genius:
  • 1,061 Answers
TRY CONTACTING THE MANUFACTURER FOR A FIRMWARE UPDATE FIRST JUST GO TO WEBSITE AND ENTER MAKE AND MODEL.ALSO CHECK WITH AOL MAYBE A COMPATIBILITY PROBLEM OR AOL UPDATE MAY HELP.HAVE A GREAT DAY.RICHARDM69
Posted on Dec 01, 2008
Dont have a cd everything else is working
http://download.cnet.com/bt-voyager-205-adsl/3000-2112_4-68694.html
http://download.cnet.com/palladia-300-400-usb/3000-2112_4-65588.html if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
eg: motherboard name wireless or ethernet driver
you might have to try a few times to get it right
hope this helps
Sep 11, 2012 | Belkin ADSL Modem / Wireless Router - UK /...
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
My Voyager modem will not recognise AOL server.
***** http://www.the-scream.co.uk/forums/t23404.html ****** Well Dahlin' , you got questions. Check out the forum I found .. the folks are a hoot. I got a kick out of it none the less. Now back to you, I think the answer lies toward the end of the page there's two different answers that should work. If not a couple of other stuff to try. Good luck. Hope it helps, if it does please rate me. thanks-jmattes
Sep 26, 2009 | Dell Computers & Internet
Installing BT Voyager 105 on XP Pro PC shows newdev.dll error
I recently had this problem after buying a voyager 210 modem/router to replace the voyager 105 (in my case supplied for AOL broadband)
I tried to uninstall the voyager 105 and encountered exactly this problem - newdev.dll missing, Admin privileges required
After alot of Internet searching I found no answers. But in desperation tried this and it worked. I am by no means any computer expert so don’t blame me if this does not work for you, or damages your machine.
To install my 210 modem I was following instructions found here -http://www.sohodata.co.uk/soho.htm But first I had to get rid of the 210
Here is what I did, exactly as I did it (some of it is probably unnecessary) Further below is a condensed version I expect would work.
1) Firstly I restarted in safe mode by pressing F8 in start-up ( I was doing this because i had remembered an administrator profile and considered attempting to uninstall from there.)
2) I logged on as the administrator.
3) Attempted to uninstall the voyager 105 via control panel and via the uninstall icon in the programme folder. - Both Failed with the above-mentioned problem.
4) I navigated to programme files. (Start> My computer> C drive> Programme files)
5) There I highlighted the folders "British Telecom”, "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", "Voyager Test". I cut these folders wholesale and pasted them to my USB pen/stick (incase I needed to put them back)
6) I then ran disk cleanup (Start> All Programmes> Accessories> System Tools.)
7) Then I turned off my computer and unplugged the USB pen/stick and the USB and DSL cables from the back of the Voyager 105.
8)I turned the computer back on (starting up normally), logged on with my normal username which has admin privileges. Ran the driver install for my new router (previously downloaded from BT at –(http://www.btopenworld.com/broadband/adhoc_pages/driver_homepage.html#yahoodrivers) It stated that a BT driver was already installed.
9) Navigated to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall …. AND IT DID IT! No error, or messages about newdev.dll or privileges.
10) This left me free to install my new driver and go through its install process ending in plugging the USB into the back of the modem and having internet again.
Here is what I expect would work
1) Turn on and log on to any account with admin privileges.
2) Navigate to programme files. (Start> My computer> C drive> Programme files).
3) Select and delete (or to be safe, cut and paste to a removable drive) the folders "British Telecom", "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", and "Voyager Test".
4) Remove removable drive and run disk clean up (Start> All Programmes> Accessories> System Tools).
5) Then I turned off my computer and unplugged existing modem.
6) Turn on computer log back onto account with admin privileges. Navigate to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall.
7) Install desired drivers/modem.
If you find this works for you too and have asked this question elsewhere, please copy this solution so others can solve this problem too
Jul 11, 2009 | Computers & Internet
Newdev.dll error and asking for admin rights on bt modem 105
If you have IE-8 installed, then uninstall it and it will start working.
You can uninstall IE-8 using this command in the run dialog box:
"C:\WINDOWS\ie8\spuninst\spuninst.exe
Regards,
Ashish
Jun 20, 2009 | Computers & Internet
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Lost internet connection. I use BT Voyager 190 ADSL modem on AOL with WIndows Vista. Power and Thernet indicator lights are on solid, but DSL and Internet indicators are off.
Sounds like there is a issue with your phone line. The DSL indicator is the phone line. Check to see if you have a dial tone or if a message is on the phone you haven't listen too, if you have message service. Try unplugging all phone connections as and replug them in again. You also might need a filter for your DSL to phone line. Also if you have an alarm that is monitoring your system, you need to by pass alarm and use a filter.
Aug 01, 2008 | Computers & Internet
Internet connection for vista
unfortunately, there is nothing that you can copy and transfer from your XP based desktop. The best solution is to call your provider and ask them for a Vista driver update for your usb modem.
Hope this helps.
Apr 11, 2008 | Computers & Internet
Connection to intenet new router
hi
to login to the router your checkk the default gateway address and type the same in to the browser and launch in to the router to do check the configuration...
mac - check in network coonections
pc - ipconfig
cheers !!!
Feb 13, 2008 | Buffalo Technology AirStation WBR2-G54S...
Computers & Internet Logo
David Payne
David Payne
