Question about Epson Stylus CX6600 All-In-One InkJet Printer
Unclogging my printer it does not print
I have an epson stylus cx6600 printer and it wont print. i just got brand new cartridges and it still wont print. i think it is clogged how can i unclog it? or do you have any other ideas? thank you very much renee
  • 11 more comments
  • Anonymous Feb 26, 2008
    Replaced my black ink cartridge.....
    and then my printer will not print.
    Checked all cords/cables.
    Replaced all ink cartridges....still no go!
  • cheffox Mar 16, 2008
    I also purchased and installed new Cartridges and my printer does not print. It just shoots out blank pages
  • dr s Mar 19, 2008
    I too had the same problem and after reading the solution checked and the hose was detached. Your solution worked but I have to say it was a challange getting the hose back on. Thanks!
  • showgun Apr 01, 2008
    Refilled all 4 ink cartridges, now none will print due to extreme horizontal banding after numerous head and nozzle cleanings. Is the remaining duabrite ink gelling up with the refill ink? If so, what's the solution???
  • ladysec Apr 03, 2008
    I have put a new black ink jet in. My printer will copy but will not print from my computer. Help!
  • Anonymous Jul 21, 2008
    tube off
  • Mjhwstow Jul 23, 2008
    I Have and Epson Stylus CX6600---it will not print. I bought new Epson ink cartriges, but still nothing. I have done a done a nozzle check---cleaned the print head, but still nothing. How do I unclog the my printer? Also it will not copy anything.
  • debr65786 Aug 05, 2008
    I just replaced ink, after doing so it said black was 100%, it would not print, i tried cleaning it several times now it say the black is empty, I see no signs of black ink on the inside or on any paper.Any suggestions?
  • uhuru10 Aug 09, 2008
    I have a Epson Stylus 640 and it will not print anything. It was cleaned, blown down with air, and the ink was replaced. Is it reading? What might be wrong?
  • Anonymous Aug 25, 2008
    The black ink is not showing up on the Nozzle Check.
    I have replaced all cartridges, cleaned the Head many times, and tried the Head alignment but no luck with the black ink.
  • dtsmckay Aug 27, 2008
    Same issue. Can see that tube is detached and see lots of ink all over the place. My problem is getting down there to reconnect the tubes. How on earth did you do it?
  • soulfuldredz Feb 25, 2009
    I have an Epson CX4800 that takes T0601-604 cartridges... the magenta cartridge has leaked severely inside the printer now it wont print is there a way to fix this issue?
  • Juanita Bacon May 11, 2010
    Are there any printers out there that does NOT have so many problems?
I had the same problem with mine, first it was just the black and then nothing would print. I just happened upon this site and it was a HUGE help www.maxpatchink.com. I copied and pasted a protion of it here. I did this and sure enough mine had come off. Now I can print again. The problem I am looking to fix now is that the quality of my printing in "Draft or Text" is not up to standard.
The CX6600 is known for.................
Attention: If are having problems with sudden lack of inkflow after replacing one or more cartridges when using the Epson C and especially the CX all-in-one printers, we have been made aware of a design issue on these printers which may cause this problem.
Some of these Epson printers have a design flaw which causes the ink purge tube under the cleaning station to come apart during cartridge replacement. If this occurs, the printer is no longer transferring the vacuum from the purge pump to the printhead. In other words, no ink will be moved through the printhead onto the paper.
You need to look under the cleaning station and determine if the pump/vacuum tube has come off, and if so, reinstall it. Click here for pictures to identify this problem and help you resolve it.
NEVER leave your Epson printer without an installed cartridge, even an empty one, for more than half an hour. The ink will begin to gel in the built-in print head to the consistency of honey! It will require multiple head cleaning routines to clear (if it does).
Posted on Mar 13, 2008
I can sympathize with your problem. I spoke to an "honest" sales rep at a leading electronics store and he suggested to clean the nozzles with a high concentration of rubbing alcohol, something on the order of 90%. Don't know if this will help but I thought I'd mention it anyway. Good luck!
Posted on Jun 02, 2007
How to change ink cartridges on Epson Stylus CX6600
i just buy new cartridge ink for my epson stylus 4100 and when i print out didnt print its only a blank page what should i do
Dec 04, 2009 | Epson Stylus CX6600 All-In-One InkJet...
How to reset epson stylus cx6600 cartege chip
there is a tool to reset the print counter on epson ink cartridge chips, but this tool can only be obtained when you are an authorised service provider for epson. and even then it is not advised to use it, since resetting these chips can cause damage to your printer's system board, the replacement of which costs almost as much as the price for a new printer of the same model.
Oct 12, 2009 | Epson Stylus CX6600 All-In-One InkJet...
do this with a little bit of care, put your mouth on the little hole on the side of the cartridge while covering the other one the on the same side and ~blow~ some strong air in just enough to get the ink out of the nozzles.
if that does not work, next time save money and get you a refill kit like this from amazon.com ( I don`t work for them)
http://www.amazon.com/Refillable-Specially-Formulated-equivalent-individual-cartridges/dp/B000Y5D65W
Mar 31, 2009 | Epson Stylus CX3810 All-In-One InkJet...
My cx6600 has new ink cartridges and acts like it is printing but the pages come out blank!
Try taking a new cartridge out and shaking it ( with your finger over the hole that the ink comes out) and then put it back in.  Also make sure that the tape that is over some cartridges' printing area has been removed.
Dec 09, 2008 | Epson Stylus CX6600 All-In-One InkJet...
PRINTER WILL NOT PRINT COLOUR
Hi..
Check the ink levels...and try to print a different color picture.try to clean the cartridge contacts and try to print..
Regards,
debroy
Nov 25, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Not printing
Epson requires that you replace empty cartridges with their branded replacements.
Otherwise your printer wont function.
Aug 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Print problem on CX6600
bonjour
je te pose une question
epson stylus cx6600 est tres bonne qualite mais ici en algerie est introuvable pourquoi?
malgré ete tres demandez dans le marche algerien
en fin j'attende votre repense
voci mon email eplf210@hotmail.com
merci
Apr 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Cx6600 printer problem
if you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Mar 16, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Won't Print
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
Jan 21, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
1,237 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
