Question about Acer Aspire 5315 Notebook
Cannot boot into operating system on Acer Aspire 5315...have changed boot order in BIOS and disabled network boot....any other suggestions?
  • leighannecoo Dec 02, 2008
    Thank you...Acer has suggested that the hard drive be replaced as well...
    President:
  • 2,110 Answers
It seems to me that ur hard drive is having fault..try to replace it...
Posted on Dec 01, 2008
Acer aspire 5315 slow. Has windows 10. Boot up says Media test failure
This generally indicates a bad HDD...but enter the bios and make sure first boot device is NOT set to Network in the bios or maybe the hdd has gone and its looking for a operating system to load....
Check cable connections (reseat),
Check jumpers on hard drive for Master/Slave or CS settings,
Check BIOS settings for boot order,
And lastly have your BIOS rescan your HD or
Reset your BIOS to defaults.....
To enter the Bios (see your computer screen at power on, your manual, or manufacturer's web site) you probably have to press something like the DEL Key, or one of the F Keys at boot up time, but the actual Key varies from model to model. Many computers refer to this as "Entering Setup", Setup is just another term for the Bios.
Setting your Bios to any safe default settings may also fix this for you.
Feb 03, 2018 | Acer Computers & Internet
My boot priority order changed now my computer wont go to my desktop
Hi!
Sorry, I hope I was not too late. You can fix priority order issue by restoring the default value of BIOS. You can do that by doing the steps below:
1. Reboot your Acer Aspire 5315 notebook.
2. Wait about 30 seconds until you see the Acer logo on your laptop screen.
3. Press the "F2" key on the keyboard to enter the Acer Aspire 5315 laptop BIOS menu.
4. Select the BIOS option "Load Default Setting" using the arrow keys on your keyboard. Then press "Enter."
5. Press the "F10" key to save the BIOS that is reset to the factory default settings.
Hope this helps.
Apr 16, 2011 | Acer Aspire 5315 Notebook
PXE-E61 error
Your laptop is trying to boot using your network card. Go into the BIOS and turn off PXE boot under the network settings or change the boot order so that your hard drive boots before network boot. While in the BIOS check to see if you hard drive is present. Usually the hard drive boots first but if the drive is undetectable then it will try the next boot option so if the problem is not with boot order then its possible your hard drive is not being detected pointing to a possible damaged drive.
Aug 30, 2010 | Acer Aspire 5315-2153 Notebook
Acer aspire 5315 beeps on startup
See here
http://www.computerhope.com/beep.htm
Mar 22, 2010 | Acer Aspire 5315 Notebook
When I turn on my Acer minilaptop it say: Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device--insert boot disk and press any key
Your BIOS setting or boot order was changed to enable network booting (Intel's PXE).
reboot,tap F2 to enter BIOS and navigate menu to disable network booting.
Mar 20, 2010 | Acer Aspire One PC Notebook
Very slow to start up
in bios set first boot device hdd, disable lan boot rom and after login in run wirte msconfig and disable all unwanted programs from startup.. i will surely increase system speed
Nov 11, 2009 | Acer Aspire 5315 Notebook
Acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315-2698 want to restore to like ner . restall from
If it has a hard drive password, you must remove it before you will be able to restore your OS.
Mar 15, 2009 | Acer Aspire 5315 Notebook
Setting new hard drive up on acer 5315 series
If the Back Up Disk you mean the 2 Recovery Disks that you have burned from the eRecovery in Acer.
You have to enable D2D Recovery on the BIOS Setup, it's usually on the second page of the BIOS Setup on a Acer Aspire Laptop.
Please Rate, Thanks
Jan 10, 2009 | Acer Aspire 5315 Notebook
Acer aspire 3515 reboot
the error you are getting, is related to the computer not being able to find a logical Drive. ( Hard-Drive Or CD Rom ) this could be caused by either A Virus. Or a corruption in the operating System. ( Windows System File Et,c )
If you check your computers manual, or website or you can enter the computers Bios screen.
Look for an option to restore setup defaults or similar, and save and exit to cmos/Exit.
Also see if there are options for using system restore. ( this is where your hard-drive will contain a seperate partition ) to enable a set of backup files to be loaded and run.
If you have a wireless network connected, remove or disable, until computer has re-booted. As your system could have been taken over by a hacker or similar program/virus.
Thankyou for using Fixya.
Mike @ compurepair.
Dec 01, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
