Question about Acer Aspire 5315 Notebook
Acer aspire 3515 reboot
Hi I have the same problem as previously listed. My screen is saying:
PXE-E61:media test failure, check cable
PXE-M0F:eXITING BROADCOM pxe rom
No bootable device--insert boot disk and press any key.
But I do not have a disk and when I press ALT and F10 as in instruction manual, computer does not reapond. It does lt me access BIOS Utilities Hello,
Having the same problem as suggested above...changing boot order in BIOS does not help and no bootable CD was provided when purchased....have disabled network boot...any other suggestions?
    Genius:
  • 1,019 Answers
the error you are getting, is related to the computer not being able to find a logical Drive. ( Hard-Drive Or CD Rom ) this could be caused by either A Virus. Or a corruption in the operating System. ( Windows System File Et,c )
If you check your computers manual, or website or you can enter the computers Bios screen.
Look for an option to restore setup defaults or similar, and save and exit to cmos/Exit.
Also see if there are options for using system restore. ( this is where your hard-drive will contain a seperate partition ) to enable a set of backup files to be loaded and run.
If you have a wireless network connected, remove or disable, until computer has re-booted. As your system could have been taken over by a hacker or similar program/virus.
Thankyou for using Fixya.
Mike @ compurepair.
Posted on Dec 01, 2008
2 Suggested Answers
syedmujahed
  • 158 Answers
SOURCE: Acer aspire 3515 reboot
Hopefully, though, there's just some craziness going on with the Boot
....suggests that the error messages you are seeing are from a failed
attempt to boot from a network source.
Check the boot order in your BIOS to insure that the hard drive is
fairly high in the list. Generally, I have it something like this:
(1) Floppy Drive
(2) CD-ROM
(3) Hard Drive
If you do this, will it boot from the hard drive?
Will it boot from a bootable CD?
Posted on Oct 02, 2008
I have a fiujitsu hard drive in my acer aspire 5315 my keyboard has no keys just some rubber tips and when i turn on its says broadcom UNDI PXE-2.1 v10. 0. 9 copyright yada yada and then it says: PXE-E61:...
The keyboard needs replacing. Replacement keyboard for your laptop maybe available from this WEB site.
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Dec 18, 2012 | Computers & Internet
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
I get an error message on startup on my Acer Aspire 5100, it says Realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE...
It is beacuse your Hard drive is not detected on the computer properly.
Try resetting BIOS.
If that doesnt work, Check whether your hard drive is good.
Nov 28, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 keeps rebooting. This is what the screen says: INTEL UMDI PXE2 REALTEK RTL8139 PCI FAST ETHERNET CONTROLLER PXE-E61: MEDIA TEST FAILURE CHECK CABLE PXE-M0F: EXITING PXE ROM That is all...
The error message means that your system is trying to boot from LAN ie... Network boot enabled in your BIOS.
Since the system can't find any where to boot from. It is restarting.
Also probably your bootloader on the harddrive is corrupt. Please reinstall the operating system using a CD/DVD.
Jul 11, 2010 | Acer Aspire 5100 Notebook
STILL SAME PROBLEM
Sounds like your hard drive is either dead or the cable or interface is not making a good connection. The computer cannot read the main hard drive that contains the master boot record and the computer is searching for a boot device. The pxe-e61 is the computer searching for a network drive to boot from. It then goes to the next device in it's menu. Need to check the hard drive and all cables and / or interface connections. Go through the BIOS settings and make sure the computer default settings are reset.
Jun 18, 2010 | Acer Aspire 3680 Laptop
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
(1) Floppy Drive
(2) CD-ROM
(3) Hard Drive
Oct 02, 2008 | Computers & Internet
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5315 Notebook Logo
626 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
