Question about Toshiba PDR-3310 Digital Camera
Power issue Battery is charged, but camera will not power up. Lens is in open position as is flash. Charge light comes on and turns to green after some time charging so power is flowing? Camera is locked in the open position as in flash. Battery is fully charged. When I press the shuter button a little red light flickers for just a second.
  • 586 Answers
   Basically this fault occure due to malfunctioning of zoom motor.And you have to replace the optical zoom lens complete assymbaly.
  Or secondly just tell you the trick,Most of time it works and some time its not.
  Dont turn on your camera from power button.While power turns off press the play button from which you see the pics.The camera will turn on and show you the pics folder but the zoom will not open, Then shift it from play mode to pics taking mode and the zoom will then comes out.
 Thanks for using fixya.
Posted on Dec 01, 2008
  • 928 Answers
Remove the memory card then remove the battery. Wait for about 5 mins then replace the battery and make sure that the cover is secured then try to power on again. Please provide the brand and model of your camera,
    Sergeant:
  • 217 Answers
Replace the battery in such issues.
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Sd10 elph green
I suggest you to once try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries. you will see a difference.Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
Oct 11, 2008 | Canon Cameras
Samsung digimax v800
The manual does not indicate what is wrong, when the green light is flashing, other than the flash is charging.
It could be the flash can't be charged, because the flash capacitor is defect, or the battery does not have enough power.
Try switching on the camera while not in automatic mode (M of so) or when in video mode. If the light on the main dial still flashes, I think you should look for another battery. But first try another battery, before you buy one. (Or test the camera with an external power supply. Don't forget to switch of the camera, every time you change the power supply.
Mar 14, 2014 | Cameras
Nikon j1 flash not working
Does the flash ready indicator also stay off, after you opened the flash and pressed the shutter release button half?
Because that could indicate there is not enough power in the battery to charge the flash.
If the light comes on, and still the flash does not fire, there would be a serious problem. My guess; that only can be solved at the service centre.
To be sure nothing else is wrong. Charge the battery first.
Then switch on the camera, open the flash, select fill in flash and press the shutter release button half. If the flash ready indicator lights, press the shutter complete and see if it works.
Succes
Jan 13, 2014 | Nikon 1 J1 10.1MP HD Digital Camera With...
My TG-810 won't charge, the lens keeps clicking open and shut...
I found that if you take the battery out, connect the charger, then slot the battery back in it started working. Not sure if it helps.
Jun 22, 2012 | Olympus TOUGH TG-310 Digital Camera
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
May 20, 2012 | Samsung DualView TL205 Digital Camera
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Toshiba PDR-3310 Digital Camera Logo
62 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
