Question about Dell Inspiron 5150 Notebook
Dell Inspiron 5150 power jack is bad
We have determined that the power jack is bad on my Inspiron 5150. I was told by a computer shop that on the Dell 5150 you cannot just replace the jack....he said that the motherboard would also need to be replaced! He made it sound like on this particular Dell model you
cannot just replace the jack. Any info on this?
Thanks,
Cathy
  • dtlcbc Jan 08, 2009
    my laptop wont power on. when the adapter is connected the lcd light with the on symbol flashes. and nothing happens.
  • 85 Answers
Replace the computer if you have to, replacing the jack would damage everything in the small computer, and oddly you have the same laptop as the one im using to type this
uh oh im rambling
well replace the adaptrer jack,motherboard
-CG
Posted on Jan 22, 2009
    Problem Solver:
  • 8 Answers
Replace just the jack. They're for sale on eBay which proves them wrong.
Posted on Jan 11, 2009
  • Dell Master
  • 5,568 Answers
Connectors, especially the smaller ones, are often soldered directly to traces on the motherboard. Unless the board has suffered mechanical damage such as broken epoxy board material or traces damaged to the point a new jack cannot be installed, I disagree with your shop's assessment.
If they did not remove the board for inspection, they can hardly state whether it is repairable or not. If the board is in fact damaged, you won't like the cost of replacing it.
Posted on Dec 01, 2008
  • 32 Answers
I've never worked on a laptop that you could replace the power connector on the laptop itself. The connector is soldered onto the motherboard and the computer shop was right. If you're daring enough, you could find a willing electronics shop such as a TV repairman to solder the connection back on with the right equipment. Replacing the motherboard would be the "right" way to repair it however.
  • 64 Answers
Contact www.e-techsiliconvalley.com
They are laptop repair expert. Give my name (Farhang) as reference and ask for help.
Tip
Service manual for Dell inspirion 1100, 5100, and 5150
Hello,<br /><br />Download the service manual for Dell inspirion 1100, 5100, and 5150 by simply click the below link.<br /><br />Note that the manual is in PDF format, so you need to have Adobe Acrobat reader already installed on your computer.<br /><br />Also, your computer configuration speed will determine how fast the service manual will load. Wait for the service manual to load completely before scrolling in order to avoid it hanging.<br /><br />It is advice able that you print it so that you can have a hard copy. Its usually strenuous reading from the computer.<br /><br /><a href="http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF%20">http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF</a> <br /><br />Good luck.<br /><br />
on Dec 28, 2010 | Computers & Internet
Dell Inspiron 5160. When plugged in then power light lights up (before hitting the power button like my 5150) and the battery light is amber. The 5160 will not do anything - not power on at all.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
May 26, 2011 | Dell Inspiron 5160 Notebook
My dell inspiron 5150 couldn't boot on or show power light.the board cant start.
The issue can be due to corrupted display drivers or graphic adapter malfunctioning.
Visit the below link for more information
http://notebook-solutions.blogspot.com/2009/07/my-laptop-computer-will-not-boot.html
Aug 14, 2010 | Dell Inspiron 5150 System Board (...
Flashing cursor on inspiron 5150
I assume the power LED is on when you boot up the laptop and the power adapter is OK.
If I understand you, the RAM module is in memory slot A and not in slot B. If not the RAM module needs to be in slot A.
When a laptop doesn't the RAM module may only needs re-seating or the RAM module is faulty.
Re-seat the RAM module, and if this then take the RAM module and get it tested at your friendly computer shop.
Dec 11, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150. Will not turn on. While plugged in and pushing the power button the battery light turns orange flickers a few times and then nothing.
its not getting power from your power cord, if you have a friend that has a power cord, try theirs. If there's a light on your power cord it should be lit up but still doesn't determine if you cord is bad.
Jul 25, 2009 | Computers & Internet
Black sreen with flashing underscore
Try pressing "esc". If it doesn't help call the dell technical support hotline. Or ask the shop.
Good luck
Jun 26, 2009 | Dell Inspiron 5150 Notebook
Need to replace Power Jack on motherboard for Dell 5150
Sorry to be negative but laptop repair is a specialist job.
Without service manuals it will not be an easy.
Suggest you ask a repair centre for a quote.
Regards Brian
Mar 21, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 Will not turn on......
had same problem, thought changing power jack would solve problem, but, it turns out the power supply is the problem,, works great with another dell ps
Jan 03, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 contact problem
Without looking at your laptop, it is hard to tell.It could be a bad solder joint or loose part inside.
Here is the manual for your 5150:
http://support.dell.com/support/edocs/systems/ins5100/en/sm/index.htm
You can look at the place where you apply pressure, and should be able to tell what the problem is.
Jan 04, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Inspiron 5150 Notebook Logo
257 people viewed this question
Alun Cox
