Question about Kenmore 82822 Electric Dryer
Control Lock stuck on Kenmore Elite he3
I pushed the control lock button and can not get it to come off of lock status. I pressed the end of cycle signal button like it says to and it won't work. Also, my husband just spent the day taking apart all the control panel stuff and letting it sit for a while and putting it back together, still not unlocking. Have also tried unplugging for an hour and plugging back in still to no avail. Help please
jsrock516
  • 5911 Answers
SOURCE: Control Panel
I believe the DRAIN/SPIN button on the Kenmore Elite HE3 will clear a locked control panel if you hold the button in for 3 seconds. This is actually a safety feature to keep small children from playing with the buttons and allows the consumer to lock the control panel. I hope that's all the problem you have and that it is not a control panel failure. Let me know if this helps. PS The matching Kenmore Elite Dryer uses the AUTO DRY LEVEL button for the same feature.
Posted on Jul 19, 2007
  • 100 Answers
SOURCE: He3 Won't start - lock door or start water flow, although dispay works with no error
The door switch is damaged and needs to be replaced.
Posted on Oct 30, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore elite quiet pack 4
You may have inadvertently locked the control panel. You should be able to clear it by pressing and holding the DRAIN/SPIN button for 3 seconds. (It should have Control Lock instructions listed righ under this button).
Posted on Jun 17, 2008
WRMtech
  • 70 Answers
SOURCE: Kenmore HE3 front load washer the control lock is on and I don't
Look close at the panel.... it will tell you what button to hold in for 3-5 seconds
Good Luck!
Posted on Feb 25, 2009
localwonder
  • 6784 Answers
SOURCE: Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
Posted on Apr 26, 2009
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer is stuck on control lock mode. Have tried pressing the end of cycle button for several seconds and control lock button stays on....dryer won't run.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#!#!
Jun 27, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer stuck on control lock mode
Jun 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Unresponsive control panel- Whirlpool duet dryer 4 years old
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Frigidaire
Jul 10, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My Kenmore Elite front loader HE3 washer will not start.
The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
Eric
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
Control lire
Feb 19, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore washer 110.45981 400
Hold down 'end of cycle' for 3 seconds. Power shd be on.
Feb 09, 2009 | Kenmore Elite 45986 Front Load Washer
The machine is stuck on control locked. nHow do I cledar this?
Feb 02, 2009 | Washing Machines
Control door lock light stuck 'on'
Unplug it for 40 minutes to reset.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 82822 Electric Dryer Logo
97 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
