Question about Jack Lalanne Power Juicer 250 Watts
Need a new rubber stopper.
The round rubber stopper that allows you to stop the juice flow while you remove the container capturing the juice has broken. How can someone get a new one. This is the only part of the juicer that is vulnerable to breaking during the cleaning phase.
  • jineen13 Dec 07, 2008
    Same problem with rubber stopper for the Power Juicer Express. Where can we get replacement parts???
  • Cindy Aspden
    Cindy Aspden Jul 06, 2018
    I've had the same problem. Likely one is supposed to purchase the entire unit. I hope not.
5 Suggested Answers
SOURCE: I have a Jack Lalanne Power Juicer. The top piece
I am also looking for the same part. I have been unsucessful so far.
Posted on May 08, 2009
  • 4 Answers
SOURCE: jack la lanne juicer
Heres where you can buy a new one:
https://www.unitycart.com/pjss/accessories/parts_classic.asp
Posted on Aug 04, 2009
  • 5 Answers
SOURCE: I HAVE A NEW JACK LALANNE POWER JUICER
The plastic top doesn't come off. Together, it's just a piece that you use to push the fruit down into the chute.
Good luck.
Posted on Nov 08, 2009
arthurbau
  • 139 Answers
SOURCE: don't have manual, can't get juicer blade off to clean
Jack Lalanne Juicer Manual
http://www.myeasypics.com/is.php?i=665112&img=1.jpg
http://www.myeasypics.com/is.php?i=665113&img=2.jpg
http://www.myeasypics.com/is.php?i=665114&img=3.jpg
http://www.myeasypics.com/is.php?i=665115&img=4.jpg
I hope this helps.
Posted on Jun 28, 2010
Can't release top
You need a man. When the machine jammed, it tightened the lid.
If you have an assistant, ask one to hold the bottom and wearing a pair of rubber gloves, try turning the top again with two hands. The gloves will help you grip.
Feb 28, 2016 | Omega Vert HD Machine VRT350 VRT 350...
How do i get the screen filter out of juicer
I had the same problem with my Salton juicer, after making a delicious juice it was almost impossible to remove the auger like many of you, with patience and lots of elbow grease I manage to take apart. Here is my solution to this problem and it works very well for me, its simple, before juicing, disassemble your juicer and add a little oil with your finger on the silicon seal (inside and outside) see picture attached, assemble the juicer.
After juicing, remove the cover, don't try removing the auger, instead grab the basket and wobble it and it should get free, it works for me and it should work for you too. Happy juicing to all!
May 20, 2014 | Salton JM411 Juiceman II Elite Juicer
My juicer leaks under the spout. I can not figure out why. I have checked all the assembly and all the directions. It is only the second time I have used this. My machine is brand new. Any though
The spout, itself is hinged. It has two positions, an upper and a lower position. (Similar to a light switch). Make sure it is in it's lowest position when making juice, otherwise the liquid will collect in the inner bowl and leak out the sides of the juicer. Move the spout to the upper position to temporarily stop the flow of juice, such as when you change glasses or receptacles. Then, put the spout in the lower position to resume the flow of juice.
Dec 26, 2012 | Jack Lalanne Power Juicer 250 Watts
I have the beaumark juice extractor BM-473 it worked then i washed the removable parts now it wont work
the first solution is half right ... there are 2 hidden switches on the machine which are activated by shafts on the pulp container and on the top lid .if either is not on then machine will not work. possibly broke plunger on the pulp container ....or broken clip that holds the container in place
Jan 04, 2011 | Champion G5NG853S Household Juice...
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 | Juicers
Cannot remove juice bowl from Juiceman 410. Yesterday it was ok.
TRY INVERTING IT AND SOAKING IN A
SOLUTION OF OXI CLEAN AND HOT WATER.
Jun 28, 2009 | Juicers
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Just stopped working
I am sorry I might not be able to explain in English very well, but I hope it will help somebody.
In my case, the pulp container was a problem.
when you take out the container, do you see the little(very very small )hole that if you push with something like toothpic it makes sound like "click, click"? I guess when we put the pulp container back, the container is supposed to push the safety button ( bottom area), but I think the part of the container that push the button was broken, and it didn't start,so I just put something small inside the hole before I put the container back to the juicer, so it covers the missing part.
Their customer service doesn't help at all, I waited 1h to talk to somebody, and he couldn't help me. so please check that part.
Sep 04, 2007 | Jack Lalanne Power Juicer (Stainless...
Champion Juicer stopped working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Nov 09, 2006 | Champion G5-PG-710 650 Watts Juicer
Jack Lalanne Power Juicer 250 Watts Logo
1,669 people viewed this question
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
