Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C keeps displaying unable to clean messasge
I have followed the user manual, but it keeps saying the same message. is it broken or is there somthing else I could do to get it printing again? Thank you
  • 1 more comment
  • rudy2toot Jan 11, 2009
    MFC-210C
    I removed the sponge and cleaned under the tap, replaced and reset the purge count as advised. Good news: I didn't tear anything up. Bad news: It did not fix the problem.
  • audit118 Jan 18, 2009
    I have an MFC410CN. Got the error 46 so have replaced the prge box. Then Followed the aboe solution The purge counter has reset to zero. But I still get the unable to clean message. Check the error code and it still says error code 46
  • frero Feb 22, 2009
    unable to unit
  • 7 Answers
Hi I found this on your website for this problem, from Poster "Trickydicky": Rank: Apprentice
Rating: 96%, 81 votes
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C): I havent tried it yet but there were many recommendations from users who did and they recommend this solution- Good Luck the service centers said it would be $70.00 just to check it before any work is done. But if it's just a matter of pressing series of buttons to reset the cleaning counter, it's worth trying. REE
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Was this solution helpful? Show your Appreciation by rating it:
Posted on Dec 02, 2008
  • 2 more comments
  • Sarah Chapman Mar 01, 2012
    thanks so much, it worked :)
  • Donald Squier May 14, 2012
    I have not been this happy since I lost my Virginity! Thank you very much! This worked without changing the ink purge box. Had it all apart and still some absorbent material left. Thought the problem was the print head jambed to the right....Now to see if the purge box is still available, or empty it and fill with something else.
  • kulovac
    kulovac Jan 23, 2013
    Thank you.It worked for me.
  • skt171
    skt171 Apr 09, 2013
    As advertised! Thanks so much.
YES, it worked! Not the remove & clean the sponges part, I would have probably bought a new printer before doing that. But I followed the step-by-step instructions that followed to reset the purge counter, & I'm printing as I type.
Posted on Feb 20, 2009
  • kentandsig Oct 30, 2010
    I thought my printer was headed for the junk pile: this routine fixed it! Where do you go to find these routines? Ps: I just purchased $50 worth of ink before the printer gave up: I hope it lasts long enough to use all of it.
Is there an inexpensive manual avail for TDC Vivid Mainliner 300 slide proj.?
I see manuals on eBay for around $14 but nothing cheap or free. It's unfortunately one of those that is just rare enough that nobody wants to cut anything lose. Sorry... You might try a Google search if you are having a specific problem - sometimes you can find a support or community forum that has a thread about the issue.
Good luck
Nov 20, 2014 | Office Equipment & Supplies
Diameter of a circle
Hello Heather ,
Keep in mind that 1 cm is 1 /100 of a meter
1 centimeter = 0.393700787 inches
so
140 centimeters = 55.1181102 inches
Jun 20, 2014 | Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
4,838 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
