Question about Brother MFC 210C All-In-One InkJet Printer
Hi, I have a Brother MFC-210C that keeps telling me its unable to clean, I followed the user manual but it keeps displying the same message, what do I do now? please help
  • 7 Answers
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Posted on Dec 03, 2008
I have got the error message " unable to clean , see troubleshooting and routine maintainance in user's guide" . I have tried all ways in the user's guide and also other suggestions. Please gi
If your your printer cannot clean automatically, your printer head is probably clogged so badly that you will have to do it manually.... your manual should tell you how to remove it...
Jan 12, 2013 | Brother MFC-210C All-In-One Printer
Unable to clean refer to users manual
Please follow the steps given in the link below to troubleshoot the issue:
Troubleshoot: Unable to clean
Aug 01, 2011 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C printer unable to clean print head. How can I clean it manually? The inkjet cartridges are full but the printer does not print. Error message on display: unable to clean.
If your printer is like the 420CN Model, do not forget to disconnect the printer for resetting purposes and connect it again and it may clean properly and run fine. Good luck! hopes it work. It did for me. My printer is working fine and I like it. It does the work.
Aug 02, 2010 | Brother MFC 210C All-In-One InkJet Printer
Printer unable to clean. Have follwed
Try this...
Go into maintenace mode by pressing ( Menu * 2 8 6 4 ) within 2 seconds. You should be in the maintenance mode now. Press 80 and scroll down to purge count, if the figure is more than 6000, press 2 7 8 3 to reset the purge count. The printer will restart and everything normal. Good Luck
Jul 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C Machine error 41
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
Dec 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
UNABLE TO PRINT BROTHER MFC 210C
Go to this link and find Page 11-4 in the section on Troubleshooting:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Let me know if this has helped you to solve the problem. Binary Bob
Dec 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean?
Heres the mauel for the MFC-210C printer.
http://www.brother-usa.com/manuals/default.aspx?PRODUCTID=MFC210C&ProductGroupID=5
You can clean the outside of the printer and the paper handling mechanisms with a mild cleaning solution and a lint free cloth. To clean the insdie of the printer, use a HEPA vacuem and follow the manuels recommendations.
Nov 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
272 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
