Question about Ovens
Beeping F11 We were cooking and all the sudden it started beeping and flashing F11. We unplugged it and plugged it back in and it started beeping again. PLEASE HELP! Can't find owner manual.
  • Frigdare F11 Mar 01, 2009
    My frigidaire keeps beeping with a F11 error. I have unplugged and plugged many time to no avail. From searching on the internet F11 is supposed to be a problem with one of the push buttons. I've removed the EOC and tested all push buttons and they are all ok. Not sure what's causing it. Frustrating and annoying.
F11  is a keypad short. This was actually a simple fix when I got into it. Take off the top rear panel. You will need a drill driver or #2 square drive. Once inside: the EOC is held in by 4 screws. Remove those and pull out the EOC.
My diagnosis on the problem is this: The keypad connection to the EOC is the thin plastic serial connector on the top of the unit, looping to the back. What I figure is that this plastic must have the  tendency to warp under the influence of heat and  thus reduces the good connection to the serial input on the EOC. There is a black plastic connection protector on the input side of the serial connector at the EOC. Gently pull this off and pull the serial connector out and give it a good cleaning. Place the serial connector back in the receiver and replace the connection protector back on. ( tricky.  if you have ever built a model or soldered anything you will be fine.)
The serial connection will need some pressure on it  to make a good connection if it is warped. My solution to this was to run a plastic cable tie thru the small holes in the top of the EOC. tighten the cable tie over the serial connector, pressing it to the top of the EOC. This gives it a good pressure on the input pins in the connection input.
Now plug the unit back in. You should have full function of the keypad. If not, it may be another issue with the keypad or EOC.  This was a solution I happened to stumble on and it may not work for everyone but giving it a shot means you might save 170 dollars in parts not including the labor.
Posted on Dec 16, 2009
  • Ginnyndoug Nov 30, 2010
    This fixed my f11 problem. Thank you very much.!!!!
I get a F11 code with beeping noise and the oven controls won't work? what can i do?
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire model fef364dsa and it blew circuit braker and now beeps and flashes f 11
F11 is for the clock/timer board error and will need to be replaced. Here is the part to order.
Be sure the unit is unplugged before replacing the part!
Also, take note of the wire harness connections.
Nov 05, 2012 | Frigidaire Ovens
Gibson oven door is locked after attempting to do self-cleaning.
Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
Sep 24, 2012 | Ovens
What is the EOC and how much does it cost to replace? Can I replace it myself or do I need a professional to replace it?
kenmore stove model #c970635326 serial #nf70205945 is showing f11 on the clock and a constant beeping noise.
when you unplug and plug it back on the clock show 12:00 for a few seconds then the f11 shows again and the continuing beeping noise
how much is an eoc to replace....can i do it myself....
Jan 09, 2011 | Kenmore Ovens
Display reads " -F3-
Replace the oven temperature sensor. Unplug the range. Open the oven. The temp sensor will be in the top right or left of the oven.A short metal piece about half the size of a pencil. Remove the screws,pull it out carefully. Disconnect the wire plug. Reverse this order to install the new sensor.
Sep 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
May 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
Ovens Logo
337 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
