My Belking G+ adapter has stopped working again. There is no signal at all from the usb.
    Master:
  • 474 Answers
Belkin adapters ****, i have had two and had the same problem i eventually went to linksys. Of course they have had some issues as well.
Try re-installing the drivers andconfiguring it to the wirless connection.
You may try resetting the router by unplugging it for 20 seconds and then back in, and seeing if that helps.
Most likely you getting booted off the network due to IP renewal issues between the router and the adapter.
Posted on Dec 01, 2008
Wirless adapter stopped working
Thanks but it's fixed. I just kept restarting it and taking the usb connection out, but I think it might be a faulty connection.
Dec 01, 2008 | Adapters.com Computers & Internet
ParkerVision Signal Max USB1500 1 Mile USB LAN Adapter, driver
I had the same problem but I eventually found the CD.
I have the driver for the Horizons USB1500 as a zip file - for free...
smpcorp@intergate.com
Jul 24, 2008 | ParkerVision Signal Max USB1500 1 Mile USB...
Hi, I have a desktop and a wireless router. The desktop was connected to the internet via a Belkin USB wireless adaptor but it has suddenly stopped and does not pick up any signal. I have uninstalled and...
Belkin products are notorious for breaking down at a high rate. If you wanted to rule out your computer as the culprit, you could install the belking adapter on your laptop (disable the built-in one) and see if it still works. I would also suggest going here:
http://www.belkin.com/support/
and typing in your product model # and downloading the latest firmware/software for it. As always, restart your computer.
Jun 10, 2008 | Belkin Computers & Internet
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER stopped working
What are you trying to connect your USB wireless device to?
Is it to a wireless hot spot?
or to a Wireless Access Point/Router?
When you find a connection, what is the signal strength?
I assume you have configured your Access Point correctly as well as making it secure. You should connect a computer to the Access Point using a network 10BaseT cable to check the Access Point configuration, especially the wireless configuration.
If you are trying to connect to a wireless Access Point and you have a weak signal, move your computer closer to the Access Point or move the Access Point to a better and higher location to give you a better wireless coverage. Note, walls can affect the wireless signals between the Access Point and the wireless network card and wireless USB device, especially reinforced concrete walls.
Jun 01, 2008 | Computers & Internet
Belkin G+ Wireless USB Adapter
What OS (Operating System) are you using??
If it's Windows 2000, XP, Vista or 7, then they MUST have any USB device plugged into the SAME USB port, or it screws up the OS.
Try going to Control Panel (Classic View), then choose SYSTEM to get into Device Manager, go down to USB and see if ANY Belkin adapters are listed (assuming the USB adapter IS Plugged In) - if you see any listed, double-click the adapters and choose to uninstall then.
If that doesn't work, then reboot, pressing F8 repeatedly before the Windows "Splash Screen" shows up. After repeatedly pressing F8 on Boot Up, you should select SAFE MODE (just the choice that only says SAFE MODE). Once SAFE MODE comes up, open Device Manager the same way you did before, then go down again to USB and Delete ANY & ALL Belkin USB adapters listed.
Then reboot and see it it recognizes the Belkin USB adapter now and hopefully will let you setup it's Software.
If you like this, please RATE me .... Thanks
May 18, 2008 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
Want to run a desktop and a laptop wireless
You need to get a wireless adapter for the desktop, either one that connects by USB or that goes inside as a PCI card. USB is easier.
Jan 18, 2008 | Medion MD 40812 Notebook
Fed up with belkin wireless G usb network adapter
I have seen this product before several times. People can't get it to install on laptops (don't know if you have a laptop) but if this is true in your case...you will need to take it back and get a different product. It won't install.
Dec 19, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
