Question about Maytag MCD2257HES Side by Side Refrigerator
Both compartments not cooling
Both compartments are not cooling. Power is running to refrig, ligths go on and off. Digital temperature buttons displaying dashes instead of numbers like usual, and cannot be adjusted. Fan is not blowing, even when push light button (door closed). Please help!
  • 1 more comment
  • aimless55303 Nov 18, 2008
    My Maytag MCD2257HES is approx 3 years old. Within the first 6 months
    the ice maker stopped working, we had it repaired, and then it quit
    again. This morning I got up to make breakfast and everything in my
    freezer was thawed. The fridge was also warm. The digital readings had
    dashes. I unplugged the fridge, and re-plugged it in. The fridge
    started running immediately, and I was able to set the temp controls.
    Upon returning from work, the unit was again not cooling, and there
    were dashes on the readout. I threw EVERYTHING away, and vacuumed
    everything I could. Now, about two hours later it is still running, but
    I don't trust it to last.
  • Anonymous Feb 21, 2009
    Neither side of my 4 year old Maytag MZD2665HES are cooling.
  • Anonymous Mar 25, 2009
    Same problem here. "Reboot" cured it, at least for the last 20 minutes.
  • 237 Answers
It sounds like the control board may be gone. If there are no fans running or the compressor running then it will never cool of course. I don't think it's stuck in defrost mode since you say the display shows dashes vice numbers. Go to this site for diagrams, etc. Item 11 is the controls section. http://tinyurl.com/3533ao
Posted on Jan 28, 2007
Seems to be constantly running. refridgerator section too cold, with items freezing.
it could be 1 of 3 things,1st: the ptc overload on the compressor has welded together and cant cycle on and off/2nd:the cold control is defective,this component is the part you set the units temperature with/3rd:your damper vent door located between the freezer and refrigerator compartments could have frozen open from condensation and cant close to keep the cold out of the refrigerator after the refrige is cool enough,this is behind a plastic grille in the refrigerator and brings in cool air from the freezer
Dec 11, 2010 | Maytag Refrigerators
1992 T&B refrig drips water from inside top of refrig compartment Is it a blocked drain tube? Or bad heater evaporator unit?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Swan fridge freezer-freezer dones,nt get down to temperature but fridge is working fine.if you turn up the thermostat the fridge acts like a freezer
There is a damper door that opens and closes when you move the thermostat. I would bet the door is functioning incorrectly. All the cooling of a refrig comes from the freezer and gets blown into the refrigerator compartment. If that damper door is open too far it will have constant freezer air blowing in....and if it's not open enough obviously the refrig will not get cool. Look at the upper left corner of your refrigerator, the center rear wall of the refrig or just feel around for a vent will cool air blowing out of it......Then take it apart and see if anything is broken.
Sep 09, 2009 | Refrigerators
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Jun 10, 2009 | Refrigerators
Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
May 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Sub Zero refrigerator
Its trying to tell you to call someone to clean the condensor.....nice feature! Sub-zero refrigs are very sensitive and will run too much and even possibly start icing in Refrig compartment.
Oct 09, 2007 | Refrigerators
Maytag MCD2257HES Side by Side Refrigerator Logo
515 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
