Question about HP Computers & Internet
I unistalled something on my pavilion dv5215us then restarted then blue screen says auto check program not found skeep check and restart nonstop
  • 64 Answers
It sounds like damaged OS or registry. You need to reinstall/recover the operating system.
Posted on Dec 01, 2008
Blue screen error
What's the first SIX lines that are displayed on that BLUE screen?
Mar 31, 2011 | Computers & Internet
Hp pavilion dv5215us laptop only show top half of screen with lines on the bottom. connect to an external monitor and all is fine. looks like a new lcd screen to me but what do i know. please help. If it...
It most likely is the display panel but there is a small chance it could be the video inverter.A new display would be fairly expensive but a good used working one would be fairly cheap.If you could get a good working one somewhere like Ebay that has the inverter with it as well would be great and still alot cheaper than a brand new one.That way you will for sure fix it with both display and inverter.Your HP dv5215us is worth repairing, especially if its been good to you other than the display problem.
Jan 26, 2011 | HP Pavilion dv5215us Notebook
Inspiron 1720 reboots randomly. tried reseating ram and cant find solution. the reboot happens usually when i try to use programs and just shuts down and restarts like nothing happened. help is very...
most likely related to the blue screen issues. a possible reinstall of the OS may be needed. To check if it is blue screen related, restart the computer, press F8 when system restarts, then select the option to disable auto-restart option on the advanced options menu and press Enter. Next time you use the system, see if it will still auto-restart or if you'll get a blue screen. If there is an error, a system rstore or OS repair or reinstall may also be needed.
Sep 11, 2010 | Dell Inspiron 1720 PC Notebook
Yesterday my dell latitude x300 started to boot up then went to a blue screen that says "unmountabe_boot_volumn. What do I do to fix it?
It's called the Blue Screen of Death. Did you install any software before it happens? If you does, try to restart your laptop then login in a Safe Mode, then go to Control Panel - Add/Remove Programs - then unistall it then restart. But if you didn't install anything when it happens, just restart your pc. If it still went to the BSC, try reinstalling your OS. Hope it helps!
Jul 19, 2010 | Dell Latitude X300 Notebook
Pavilion 510c PC Desktop: it wont boot ...it will come on but it will then g...
Hi if u get an error message after u log on to the desk top then u need to go to start ?run ?type msconfig? (do a clean boot )this is how u do? go to the startup tab click on disable all ? click on apply ?go the the services tab then check the box that says hide all microsoft services?then click on disable all ?u might get a message that access is denied dont worry click on ok and then close the page.It will prompt u to restart the computer ,restart it and then check u should not get the error message .Then u need to go to the same screen by typing in msconfig and then u need to find the program that is causing the error to come up .First enable all the startup items restart the computer and then check for the error if it does not then uncheck alleast 4 programs restart the computer and then check if u get the error or not so this way you will have to find that particular program that is causing the error to pop up and once u have found it just uncheck that particular program .
all the best
May 05, 2010 | HP Pavilion 510c PC Desktop
My HP Pavilion dv5215us PC Notebook will not turn on. The screen stays blank. Also it will not turn on when the battery is removed and the charger is still plugged into the PC. What is my problem?
Try removeing the battery, memory and harddrive.
If you can get to the CMOS battery, unplug it as well.
Open the lid and push and hold the start button for 30 seconds.
Re-install the removed items and power up unit.
Nov 30, 2009 | HP Pavilion dv5215us Notebook
Stop Error Vista Blue Screen
HI,
To determine what is causing the issue just restart the pc and keep pressing f8 key - this will take you to advanced boot meny.
First of all login to safe mode and check if problem persists there - if no go to start and in start search bar type in MSCONFIG - then hit enter.
After that go to startyp tab in system configuration window and click on disable all startup items.
Restart yuor pc in normal mode and if problem will not persist keep enabling startup items one by one. This will allow you to determine which software is cauusing the problems. Then update that software. Unless it is really old it should work with vista.If that is xp only software you will be able to use that in Windows7 under xp mode. Check Mocrosoft website for more info on XP mode.
BR
SRG
Oct 26, 2009 | HP Pavilion Desktop with AMD Phenom X4...
I have a hp pavilion dv6000, when I start the computer windows go up but in a few minutes the screen go to blue and restart again and very slow.
there are alot cause of blue screen and auto restart,,1. some part damage or bad, 2. Operating system damage,3. if you installed some program not compatible in each other files system..
To Do....
chech the hdd..2. use another hdd, if the same, remove the cd room drive. use external cd or dvd room drive..
Jun 06, 2009 | Computers & Internet
After blue screen restart the computer always
sounds that you have a virus problem so quickly get an updated antivirus from listed below esp
bitdefender
webroot
kasperkey
avg 8
nod32 etc
Mar 10, 2009 | HP Pavilion dv1000 Notebook
Webcam not found
I have found that if the webcam software has a program that automatically starts its own OEM program then you have to open that program and find the settings for turning it off or on. Two programs will not want to share a webcam.
Sep 05, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
